The M30 runs!!!!!!!!!!
  • rs4pro3
    • 5808
    I got my cleaned and flow tested injectors back today from cruzin performance and tried starting the engine but no go, so after dark I started trouble shooting and found out the fuel pump relay had a bad ground, I grounded it right to the chassis, and the engine started before one revolution :twisted: With the 11lb flywheel it revs nice and fast it went from 1,000 rpm's to 3500 almost instantly. Next week I'll pull the m30 out of the parts car, and then december 16th after my last Final exam the m20 comes out and the m30 in. :D :D
    85 325e 2.7 ITB'd stroker
  • M-technik-3
    • 18946
    Now why did you install it in the junker again?? Seems to me like double work for no reason.
    Edit: Forgot to congratulate you. Glad to see it done finally. Gets some numbers.
    • Rob
      • 8166
      that was my thinking exactly
      BEERTECH
      • Schneider325
        • May 2004
        • 3818
        Maybe so he could avoid mistakes done the first time...idk, save a couple dings in the paint job maybe?
        • george graves
          • 19993
          It's not a easy install .... congrats man!
          Originally posted by Matt-B
          • Stu Mc
            • 4083
            I dunno, if I had spare E30's like Ely, I'd probably do the same. Less down time on your daily driver I suppose
            • Jon325i
              • 6934
              I was thinking on the same wavelength ;) Plus, its good to know the motor starts and runs well before you install it your car.
              Jon
              Rides...
              1991 325i - sold :(
              2004 2WD Frontier King Cab
              RIP #17 Jules Bianchi
              • rs4pro3
                • 5808
                Exactly, I put it in the parts car to get everything lined up, wiring taken care, and exhuast. This way it will be a direct bolt in swap, the only fabbing needed will be some firewall pounding and a heatshild for my cold air intake.
                The engine had sat for over a year so I wanted to make sure it runs before I pulled the engine from my daily driver.
                • Ryan Stewart
                  I Love Miatas
                  • 8978
                  I wish I had a shell to do all that in. It would have been nice to spend a couple months making everything perfect so I could just toss the engine in the daily.
                  Im now E30less.
                  • rs4pro3
                    • 5808
                    yep, I haven't made everything to perfect as it's an 87 and my car is an 88 and has some frame damage so stuff will fit just a little different, but the driveshaft, shiftlinkage, is ready to bolt in. Plus I'm going to replace the subframe and trailing arm bushings so I wanted to allow time to do this as school starts back up january 18th.
                    • randomtask37
                      • 3154
                      awsome! glad to hear its finnaly up and goin.
                      which car is it in right now?
                      98 M3/4/5
                      • rs4pro3
                        • 5808
                        my 87 325is parts car
                        • M3 Ryan
                          Site Sponsor
                          • 2298
                          Another thing you guys should know about this swap is that the engine comes in and out several times if you are fabbing parts.
                          George and I made our own motor mounts for the furthest position back to save the handling and distrubiute the weight evenly. This required the engine to be put in and pulled out 4 times that I clearly remember, one of which we dropped the whole suspension out to do.
                          '88 M3.2 S54 Lachssilber/Black
                          '07 335i Alpine/Black Sedan
                          '12 X5 3.5i Alpine/Black
                          iS Splitters For Sale, PM ME!
                          • rs4pro3
                            • 5808
                            Ya, Mine came out twice just getting it into the parts car even with the mounts allready purchased.
                            • george graves
                              • 19993
                              Oh come on guys - the m30 bolts right up! (kidding)
