'01 dodge neon engine missing?
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    They will get a P-code, I don't know how much more specific you'd want.
      • 37833
      I think a code for cylinder 4 misfire is a pretty good indication. ;)
      Pretty much says, check the plug, check the coil, check the injector, check the wiring to those things.
      Grover Beach, California
      BimmerHeads.com
      • Jean
        • 18228
        OP - good luck! In my case I was just getting a P0304? misfire on cyl # and putting new plugs/wires/set of injectors/coil(s) didn't do a thing. Even checked compression and it's even on all four. It misfires hard enough to notice it running rough, and it does this usually right after filling the car up.
        • Farbin Kaiber
          Lil' Puppet
          • 29502
          Didja check FP Jean? Maybe a sticky injector. Or, valve adjustment. Was there a random misfire code too?
