Brake bulb grease?
  • rwh11385
    lance_entities
    • 18403
    Brake bulb grease?
    The check light is coming on for no good reason (i.e. bulbs are functional)
    Parts guy gave me some lube / grease / gel one time that he said to coat them. Did so for my 540i but don't have any more / 325is needs it.
    What is this electro-conducting lubricating gel that helps make the check panel not go on for faulty sensing?
  • E30SPDFRK
    • 5712
    dielectric grease
    Byron
    Leichtbau
    • Mike
      • 932
      neosporin/ clear stuff, not the white stuff
      Supatek -noun - your basic know it all
      • Wh33lhop
        • 11705
        Originally posted by E30SPDFRK
        dielectric grease
        Dielectric means insulating and dielectric grease is just that.
        Just go to your local electronics or hardware store and ask for conductive grease.
        paint sucks
        • Aptyp
          • 6584
          advance and autozone both have little 99 cents things with electric grease. Same grease for bulbs and sparkplugs.
            • 34844
            actually, it doesn't matter. you don't want conductive grease. it could cause shorts. dielctric grease is also used in spark plug wire boots.
            I used to use this stuff to keep the pins on my old Pentiums from getting water condensation in them when cooling them to -40c. It doesn't stop the pins from contacting each other, it just keeps air/moisture from contacting the metal.
            • Wh33lhop
              • 11705
              I know what it's used in, he asked for a conductive grease is all.
              paint sucks
                • 34844
                it doesn't need to be conductive like I said. It only fills in the air pockets, there is still going to be metal/metal contact.
                • rwh11385
                  lance_entities
                  • 18403
                  Yeah, so it doesn't need to be conductive like i thought. Whatev... thanks for the quick reply E30SPDFRK
                  • DragonOrta
                    • 262
                    What did you use? A single stage phase change? Dry ice in a pot?
                    Cornering is like bringing a woman to climax.
                    -Jackie Stewart
                      • 34844
                      two 75w peltiers (single stage, side by side), water cooling. actually got them down to -50c by running cold tap water direcly through the system (the water in bellingham isn't metered). Except the peltiers required their own power supply and it probably cost as much in power as to buy a faster machine. But of course I wasn't doing it just for the performance. :)
                      • SpecM
                        • Oct 2005
                        • 4531
                        make sure the contacts in the bulb sockets are making full and clean, well... contact
                        1989 cirrisblau-metallic 325i
