Cant budge the diff fill plug - Any suggestions?
  • txtorquemade
    • 1758
    This is posted in the tech forum, but more people come here..soooo.. pardon the double post.
    I cannot budge my diff fill plug. (Glad I didnt get the drain plug out first, right....)
    Using the BavAuto BMW specific socket and a ratchet ( I broke two ratchets trying to get this fdcker out) and spraying with pen oil still wont budge.
    Im going to get a short breaker bar 3/8 drive as that is what is needed for the socket. Any other ideas???
    sigpic 1987 325is
  • Ben Carufel
    • Jun 2004
    • 5248
    Hit it with an instant shot of torque. Put a breaker bar on it and hit the breaker bar with a 5lb sledge.
    If the plug doesn't come out just get a new diff cover and gasket. You should be able to find a used diff cover with plugs for $25 or so.
    • lifeiskaos
      • 1709
      you could also try putting a pipe on the breaker bar for more leverage
      • LosBemmer
        • 65
        you could use some dynamite!!:)
        • Erick
          Official R3V Drifter
          • 11169
          What he said. If all else fails... diff covers are easily found.
          ..::Support FullOpp::..
          FullOpp Stickers for sale!
          Feedback Thread
          • Julien
            • 7471
            breaker bar + muscle usually does the trick. you'll hear a rediculous crack noise as it loosens up too :-)
            Build Threads:
              • 34844
              using a rachet to break a stuck bolt free is an excercise in futility. buy a breaker bar, they're like $15..
              • Beach Bum
                • 466
                Pull the cover and put the fucker in a vice with a 6 ft. breaker bar or an impact. It'll come loose.
                If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                • shiftbmw
                  • Oct 2005
                  • 2012
                  Works every time.
                  "The best argument against democracy is a five-minute conversation with the average voter." - Winston Churchill
                  • e3niner
                    • Nov 2007
                    • 14
                    Had a similar issue with the transmission fill plug recently. Ruined a ratchet trying to loosen the plug with a cheater. Breaker bar & muscle finally got it free.
                    • bwanac
                      • 3354
                      Yes, stop killing ratchets.
                      • crashoverride7
                        • Jul 2008
                        • 65
                        one other note, unless you really like breaking tools, buy a 1/2 inch drive breaker bar to get that plug loose, not a 3/8. you will just snap the metal square that goes into the socket with 3/8ths if youve already broken ratchets. and putting cheater pipe may help, but thats a do at your own risk as well.
                        {ninja edit} or try a 6 point wrench and a dead blow hammer. and use pb blaster. you can take apart the whole goddamn world with that stuff.
                        • graphikg
                          • Jan 2008
                          • 1614
                          • willybustaE30
                            • Apr 2006
                            • 143
                            try using the fire axe. (lil bit of heat=torch) heat the cover up a bit around the plug. not directly on the plug. this will expand the the metal a bit thus making easy to remove.
                            ive done it lots of times on diffs,trannies,& transfer cases.
                            • txtorquemade
                              • 1758
                              Am getting a breaker bar, and will try the heater on the cover AROUND the plug. ( I get it!!)
                              Are the tranny plugs as hard as these diff plugs???
                              Thanks for the comments guys...
                              sigpic 1987 325is
