smell of gas?
  • pitbull09
    • 101
    smell of gas?
    Ok during the past few days I seem to be getting the smell of fuel in my 88 cabrio for some reason? Esp right after start up. I've looked under the hood and can't seem to find anything leaking like an injector or fuel line. Does anyone have a clue where this might be coming from? Has anyone else ever had the same problem? Is there some way fumes could be backflowing out of the K&N somehow? I have no clue but any help would be appreciated.
    Also on another note I would like to know if anyone here has a set of rear eibach springs for the cabbie? All I need is the rears though. If I have to I'll buy a whole set but I'd rather just buy the rears since I already have the fronts. Please let me know.
    TIA,
  • backtrail69
    • Jul 2005
    • 4471
    Seeping soft fuel lines is my Number 1 guess. It has happened to me before. If you can't find it. You might want to bring it by a mechanic. This is a serious safety issue.
    :: PNW Crew ::
    '87 325 4dr, '74 2002
    • transatlantic0207
      • Sep 2007
      • 1624
      maybe faulty cold start valve? how's the idle on start up?
      (OO≡≡[][]≡≡OO) ///Motorsport
      In this world, things aren't black & white. Its Delphin!
      Parts, Buy Them--> http://picasaweb.google.com/transatl...eat=directlink
      Snowboard & video game stuff --> http://r3vlimited.com/board/showthread.php?t=148645
      Originally posted by Steve92E34
      Your car is breathing my air, and so are you.
      AND you are both still slow
      • pitbull09
        • 101
        yeah esp since I've got my 3yr old with me I def don't want any problems! I'll take a good look at the lines and see if mabey I can pin point the source a lil better. Thanks!
        • pitbull09
          • 101
          Eh the idle is oook i guess mabey a little bit of a fluctuation up and down but nothing major really
          • pawi30
            • May 2007
            • 1091
            have you checked by the fuel filter?
            Originally Said by Bob Marley
            "BMW make pure trouble!"
            • Emre
              • Sep 2007
              • 1228
              Might sound like a stupid question, but are you 100% sure the smell is fuel and not just an exhaust leak? It can be hard to tell the difference sometimes.
              1987 Mercedes 190E 2.3-16: Vintage Racer
              2010 BMW (E90) 335xi sedan: Grocery Getter
              • Mike30e
                • Jan 2009
                • 408
                I'm getting the same sort of thing, definite scent of fuel at cold start up, idle is okay until warm then it ocillates up down by about 100-150rpm's. Does it frequently but not all the time...
                • Naplm00
                  • Nov 2008
                  • 1573
                  also check the metal fuel return line on the car
                  mine rusted through and was leaking
                  88 325ic ~~~> Rusty and ugly
                  85 E ~~~> RIP
                  • delatlanta1281
                    Dart Master
                    • Mar 2006
                    • 10317
                    Could be leaking out of the FPR seal at the end of the fuel rail, they can leak slowly. Put your finger under the end of the rail and see. It may be running down the side and you may not be able to see it.
                    Yours truly,
                    Rich
                    you kids get off my lawn.....
                    • TexasTerp
                      • Jan 2009
                      • 3541
                      re-check your injectors and fuel rail again, I had this happen a few years ago, turned out to be two fuel injector seals.
                      stephenbrody.com
                      • txtorquemade
                        • 1758
                        Some good ideas. Happy wrenching!!
                        sigpic 1987 325is
                        • twright
                          • 707
                          Take out the bottom of the back seat and take off the cover on the passenger side. Its where the fuel pump is.
                          Look there and see if you find fuel.
                          • pitbull09
                            • 101
                            awsome guys I`m going to jump on it tomorow and go through the replys one by one till I figure it out. Thanks for all the help!
                            • AndrewBird
                              The Mad Scientist
                              • 11897
                              That is what I was going to suggest. The seal around the opening often leaks. It could be the fuel lines there as well however.
