Removing spring pads...
  • 88SuperETABD
    • Apr 2009
    • 911
    Dunno how to go about doing this...is there any write ups? Is it easy? never really messed with any suspension...But i wanna lower the front more...heard spring pads removed = ~1/4" drop
    (SOLD) 1988 327i Build Thread: http://www.r3vlimited.com/board/showthread.php?t=155086
    1970 Gruppe 2 2902 M20 Turbo Build: http://www.r3vlimited.com/board/showthread.php?t=373891
  • Asbradley21
    • Jun 2008
    • 1938
    it's pretty easy for the back, just pull on the trailing arm after unbolting the shock. The front, not so much. You might get luck and you can get up under there with a knife or something and cut them out if your spring sits a little loose. However, if you have stock suspension, that probably won't happen and you'll have to take your strut assembly all the way out.
    S54B32 swap in progress. Status: Getting There
    • Nic01101011
      • Jan 2008
      • 1549
      you might be able to fit a spring compressor on the front springs with them still in the car(and the car jacked up) and just pull the pads out. a waste though, you won't lose any significant ride height in doing that.
      • IRON-E
        • 16548
        +1 best advice so far ^^^
        @IRON-E30 aka Edwin:D
        • Red88
          • Nov 2008
          • 1160
          I'm pretty sure you'd get more like 1/8" drop. These things are thin, you wouldn't be able to tell even by putting two cars right next to each other with the exact same suspension setup, except one doesn't have pads.
          Have you made a purchase from www.blunttech.com recently?
          sigpic<< wrecked
          • graphikg
            • Jan 2008
            • 1614
            Ya. I dont think you will get a drop and it may even be noisier. It will be metal on metal basically.
            • 88SuperETABD
              • Apr 2009
              • 911
              Alright....well cheapest alternative to tuck the front...Camber plates that actually work are way too expensive... heres a pic of what im dealing with. Im satisfied with the rear. i just need to drop the front more.
              • E30_Pare
                • 7801
                holy reverse rake batman!
                DREWLIENTE
                1$ PShops PM me
                • graphikg
                  • Jan 2008
                  • 1614
                  Just worry about the drop when you get upgraded shocks and springs or coilover kit. Dont do shortcuts until you can do it right. Plus, itll perform better.
                  • Danny
                    • 14216
                    Cut a dead coil.
                    Problem solved.
                    • yberther
                      • 1246
                      Originally posted by Danny
                      Cut a dead coil.
                      Problem solved.
                      Flickr
                      Originally posted by Indecline06
                      For some reason, when I get super duper ultra stoned... The M30 motor reminds me of big bird from sesame street.
                      • N2MYE30
                        • Oct 2007
                        • 5536
                        First ya gotta get rid of the reverse rake! Put the original springs back in the rears and take the rear pad out. There are some companys that will just the front springs. It looks like your gonna need about a 60mm drop to get the look.
                        COTM
                        • txtorquemade
                          • 1758
                          Cheapo method = cut a coil off of front springs
                          Best method = coilovers, HR springs/Bilsteins, etc.
                          I would do it right though.
                          sigpic 1987 325is
                          • 88SuperETABD
                            • Apr 2009
                            • 911
                            how bout...cut a coil off front till i can afford GC's
                            • Jand3rson
                              • 37587
                              Yet another reason early-model cars rule, and late-models can suck it. Like Matt Lauer.
