Adjusting Valves for 2.7i....
  • dager325
    • Nov 2007
    • 185
    Anyone know what they shuold be???
  • Mike
    • 932
    Supatek -noun - your basic know it all
    • Need4Speed1299
      • Oct 2007
      • 119
      Adjust to .010 when cold.
      http://www.pelicanparts.com/bmw/tech...lve_Adjust.htm
      • ///M42 sport
        • 3952
        so the article in pelican says to jack up the car on one side IF the car doesnt have LSD. so if I have a LSD then I jack up the both rear wheels?
        • Adrian_Visser
          • Jun 2006
          • 2823
          Fuck that shit. take out all the plugs put it in neutral, e-brake on and a (disclaimer: fused) jumper wire between pins 11 and 14 of the diagnostic connector (on late model connectors.)
          It bumps the starter just tap it bit by bit.
          You could go through the trouble of putting a momentary contact switch in the wire to make it easier but I did it with just a piece of wire and it worked great.
          '89 Alpine S52 with goodies
          • ///M42 sport
            • 3952
            what about just turning the crankcase bolt?
            • ForcedFirebird
              • Feb 2007
              • 8300
              I leave the car in neutral and rotate the engine by hand - just use a long breaker bar/ratchet if you left the plugs in.
              john@m20guru.com
              Links:
              • Gruelius
                • Oct 2009
                • 298
                does the gap depend on age?
                ive got 280,000kms on a unopened motor, when gapped to spec my car sounds like a turbodiesel lol people told me to do it a bit tighter next time.
                RIP 84 323i coupe 5spd w/ 14psi
                89' 318i
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  I have gone as tight as .006" cold with no problems on higher mileage motors. Really quiets the "sewing machine" lol.
                  john@m20guru.com
                  Links:
                  • Nic01101011
                    • Jan 2008
                    • 1549
                    just turn the crank pulley end with a wrench
                    • ///M42 sport
                      • 3952
                      From pelican article "Once you have adjusted both the exhaust and intake sides of the cylinder, you will want to take the parking brake off, and PUSH the car in 5th gear until the cam lobes are in the proper position to adjust the second cylinder. "
                      Pretty retarded...
