Why Do People hate the 318 so much?
  • tjts1
    • May 2007
    • 1851
    #166
    Originally posted by 2002maniac
    I strongly disagree. I have tried both 3.64 and 3.73 and both returned worse mileage than 4.10 gears. The M42 simply does not have enough torque to go lugging around in the lower revs. 3500-4000 rpm on the highway IS NOT A BAD THING.
    Thats because you're doing it wrong. And yes 3500-4000rpm highway is a bad thing. Its bad for my ears.
    Originally posted by nando
    I disagree on the good design. The crappy timing chain system that has a tendancy to grenade and profile gasket are two pretty big strikes against it, plus the inner oil pan bolts falling off and blocking the oil pump and the ungodly nightmare of vacuum hoses under the intake manifold.
    I'll be sure to let you know when my crappy timing chain and profile gasket 'grenade'. Going on 170k miles and counting. Don't hold your breath.
    • Highway1
      • Jan 2009
      • 773
      #167
      Crap, i didn't mean to create an m42 vs. m20 discussion.
      back on topic... kinda. m42's ftw :p
      Turbo?
      NA?
      info on the NA setup:
      here's a detailed list of the complete install possibilities
      Performance kits for BMW M42B18 Engines
      Step I : Upgrade to 114kW / 156HP
      includes:
      • A throttle body injector system 1453,--
      • Complete software update 355,--
      • Fitting of the throttle body injector system 261,--
      at dbilas dynamic
      Completeprice including fitting at dbilas dynamic 1995,--
      You save 74,--
      Step II : Upgrade to 124kW / 169HP
      includes:
      • A set of sport camshafts 587,--
      • Fitting of the sport camshafts 294,--
      at dbilas dynamic
      Completeprice including fitting at dbilas dynamic 2850,--
      You save 100,--
      Step III : Upgrade to 132kW / 180HP
      includes:
      • Cylinderhead and Valve modification 845,--
      • Fitting of the cylinderhead 717,--
      and the sport camshafts
      at dbilas dynamic
      Completeprice including fitting at dbilas dynamic 4090,--
      You save 128,--
      Step IV : Upgrade to 140kW / 190HP
      includes:
      • a/N 2000 control unit to replace the 889,--
      air flow meter
      at dbilas dynamic
      • tehwickerman
        • Dec 2008
        • 1088
        #168
        m42 with lighter flywheel>m20 cars all day. I've owned both, haven't drivin an m20 with upgrades except for a 4.10 and I'll definitely say my m42 feels quicker with the lightened flywheel and is much more fun to drive. For those saying the m42 is a shitty designed engine i definitely beg to differ. Its a very tough and robust engine and i prefer chains over belts. plus with all that extra room in the engine bay they're easier to work on :D
        • fiftytakedowns
          • 2460
          #169
          that dbilas stuff looks awesom
          [/url]
          Team USA Wrestling 67KG
          • herbivor
            • Apr 2009
            • 1420
            #170
            includes:
            air flow meter
            at dbilas dynamic
            I'll take one. Where do I send the check? Seriously
            • Wh33lhop
              • 11705
              #171
              includes:
              at dbilas dynamic
              You save 128,--
              There's how you get your 180hp. :p And am I missing something or are all of those setups still running a dizzy?
              paint sucks
                • 34839
                #172
                hmm... i haven't had any of those issues.
                Ask yourself these two questions:
                How often do you hear of a bad timing system ruining a m42 motor?
                How often do you hear of a timing belt breaking on a m20 motor?
                I don't know, I'd never let my car get to the point where the cost of a $30 timing belt kit was going to grenade my motor. have fun spending $800 on chains, guides and rails at 200,000 miles, plus labor and downtime. Oh wait that's the cost of an M50 swap... and why I ended up not buying my friends 318is (the car was worth far less than that).
                my engine is non-interference anyway, so I could care less if the belt went out.
                that's a really sweet looking turbo setup btw, PPF makes nice stuff.
                  • 34839
                  #173
                  M42s are sequential injection/ignition, there is no dizzy. ;)
                  • FredK
                    • 14761
                    #174
                    Attention: nando is crabby today.
                      • 34839
                      #175
                      every day, man ;)
                      • z31maniac
                        • 17566
                        #176
                        A half-assed M50 swap.
                        www.gutenparts.com
                          • 34839
                          #177
                          so, 95% of the M50 swaps on this forum? ;)
                          • z31maniac
                            • 17566
                            #178
                            Touché salesman.
                            www.gutenparts.com
                            • pbr87
                              • May 2008
                              • 853
                              #179
                              Originally posted by highway1
                              crap, i didn't mean to create an m42 vs. M20 discussion.
                              Back on topic... Kinda. M42's ftw :p
                              turbo?
                              win!
                              Originally posted by accident
                              I have achieved the title of Douche of the month.
                              Discuss.
                              Originally posted by kronus
                              It was probably pissed off because it didn't want to pay taxes for poor people's healthcare.
                              1990 300ZX TT 5spd ($6,000)
                              1991 318i 4dr 5spd (DD)
                              • TooTall90
                                • 338
                                #180
                                nando, an equal opportunity offender lol. so im guessing you are not fond of the M42?
                                i have to agree with what they were saying above, you do not hear about a whole lot of grenading M42 stories, not even on M42club where everyone has an M42. which is the opposite when talking about m20's.
                                and of course it could be only the "n00bz" that would let this happen, but i think its safe to say if those "n00bz" had an M42 they would still be on the road driving an e30.
                                so i think it comes down to this, the m20 is hands down the more "powerful" engine but there is no arguing that the m42 requires less maintenance to maintain on the road. the snakepit under the intake does not damage the car, the loose bolts in the oil pan are a quick and free fix assuming you have the tools. and the big one, the timing chain i guess its like you said nando either replace em or swap. i'm doing the latter when my 318 reaches that point. ;)
                                Strategic Alpine Command:...sig loading
