vibration dampener
  • jeffw
    • 1087
    vibration dampener
    I bought a brand new drive shaft and it has a vibration dampener on the front end. I want to take a sawzall and cut it off cause my shifter rubs on it and i don't like that. Is there anything i need to worry about with doin that?
  • 87-325ic
    • Apr 2006
    • 1198
    yeah. you dont need to sawzall that thing off.
    it twists off the bolts a certain way, but i dont remember exactly.
    i took mine off a while ago when i did my guibo/ csb and shifter stuff.
    • Bimmerista
      • Nov 2005
      • 5425
      Just make sure you don't screw up anything else and you're fine.
      • jeffw
        • 1087
        this one isn't bolted on. I believe its welded on. I figure if i just cut about a half inch away from the drive shaft it should be fine
        • newman
          • Mar 2007
          • 1159
          Since you're clearly looking to have an unbalanced driveshaft by hacking it off with a fucking sawzall, I'd smash it with a sledgehammer a few times too, for good measure.
          1987 325is: 495whp/400ft-lb
          UPDATED 03/12/10!: RB26DETT Swapped E30
          • jeffw
            • 1087
            lol its at the front connected to the tranny. its not gonna unbalance it.
            • twothrees
              • 252
              That was funny, thank you.
              • newman
                • Mar 2007
                • 1159
                Oh good point. I always forget that E30s operate outside the laws of physics.
                  • 34844
                  it's actually very common to remove them. I think BMW was going for overkill in this case. Sort of like the pulse dampers in the early fuel systems that get removed because they leak and cause fires. Just not as deadly.
                  I don't know about using a sawzall on a driveshaft though..
                  • newman
                    • Mar 2007
                    • 1159
                    I'm not saying you can't remove it. You certainly can, and you probably wont notice it... if you do it right.
                    But:
                    A) Removing it with a sawzall is going to make it unbalanced
                    B) The degree that it's unbalanced is a function of deflection. Even though this is, in turn, a function of distance from an axial constraint, it's NOT going to alleviate a potential driveline shudder...
                    • vicrossi
                      • Jan 2010
                      • 35
                      Does anyone know the correct way to remove the damper?
                      • 36brua
                        • 689
                        maybe this for damper on DS
                        My CA legal M60 swap
                        The happening in our garage
                        • pbr87
                          • May 2008
                          • 853
                          Why not just remove the driveshaft, take it to a driveshaft shop, and pay them like 60 or 70 bucks to remove it and balance your driveshaft afterwards?
                          Originally posted by accident
                          I have achieved the title of Douche of the month.
                          Discuss.
                          Originally posted by kronus
                          It was probably pissed off because it didn't want to pay taxes for poor people's healthcare.
                          1990 300ZX TT 5spd ($6,000)
                          1991 318i 4dr 5spd (DD)
                          • T Verdier
                            • Aug 2007
                            • 2636
                            My mechanic sawed it off when he did my short shift kit.
                              • 37833
                              Why not pop out the studs, remove and dampener, and replace the studs along with washers about the same thickness as the dampener? That's what i usually do anyway.
                              Grover Beach, California
                              BimmerHeads.com
