miller maf, or megasquirt?
  • KillaCams
    • Mar 2008
    • 998
    Seems like it would make sense to try the 173 ecu first and see if that fixes anything, MS is a big step and i doubt you will see much gain on a stock motor
    • 87-325ic
      • Apr 2006
      • 1198
      Originally posted by shiftbmw
      Idle issues could be unrelated to the two codes...ignition, ICV, etc depending on what exactly the problem is.
      I know a bad cap and rotor have been known to make cars feel like they hit a brick wall at certain rpm.
      I also assume you've tried to chase down all vacuum leaks?
      new wires, plugs, dist, and rotor a couple yrs ago. i guess it seems a little old now.
      ICV is clean and works.
      the drivability issues i talk about are really more like valves that are out of adjustment by alot. but i just adjusted them.
      now for the threads sake, lets try to get back to the original question. my problem should be in a new thread.
      • gearheadE30
        • Jun 2007
        • 3734
        I'm building Megasquirt for my M42, and it really hasn't been difficult thus far, except for the M42 ignition coils. I hevan't installed it yet, but there is a ton of support and it isn't too expensive. Adding a MAF may even make things worse, and you can get a lot more out of megasquirt. It is all very well documented.
        Project M42 Turbo
        • tjts1
          • May 2007
          • 1851
          Megasquirt it. You can have it up and running on $300 includin wide band O2.
          • 87-325ic
            • Apr 2006
            • 1198
            care to elaborate?
            btw i checked/ changed my o2 sensor, It was pretty white but not too bad. It def was running lean when my valve cover was leaking.
            it seems to run a little better now, maybe its placebo. but i still get the CEL...
            gotta be the ecu!?...
            So its looking like, 173 ecu and maf (maybe), or dump it all and go MS.
            • matt
              • 3731
              If you can't make a stock e30 run right, what chance do you have with megasquirt?
                • 34839
                for what? an MS1 V2.2 with a home built wideband controller? No thanks.
                A worthwhile MS2/V3.0 with a real wideband (Innovate, AEM, etc) is going to cost $800 minimum, all said and done. that's before you've touched a dyno.
                • BeirBrennerE30
                  • 2740
                  so you have a car that runs poorly... and you want to swap in a ECU that is even less capable of controlling your engine to solve the problem? It wont mean your problem is fixed. It just means your new ECU is too stupid to tell the difference.
                  e30sport.net
                  '06 M3 Competition - 6-speed
                  '97 Range Rover Vitesse
                  • kid325e
                    • Sep 2007
                    • 6421
                    This isn't what you want to hear but sometimes if you can't figure out a problem with your car maybe its best to just man up and pay to get the problem TRULY diagnosed. Bring it to a reputable shop in your area with good knowledge of e30s.. check the bmwcca member boards in your area, they will have the best reviews on what shops are worth your time and money. Best advice I can give you.
                    No upgrades till you get it running right. Matt has a point if you can't get your car running right with the work you've done, you have no business with a MS system. If you MUST go your way, go with the miller MAF, less ways to fuck up imo.
                    clutchCTRL!
                    Move with a purpose.
                    - 1991 325iX 4dr/5spd
                    - 2000 323i AT
                    2016 Mazda CX3 Sport AWD
                    • tjts1
                      • May 2007
                      • 1851
                      MS1 extra_HR gets the job done and then some. If you want to waste your money on MS2 that's your choice but MS1 will put you way ahead of the stock ECU. I'm not sure what your definition of a 'real' wide band O2 sensor is but most use exactly the same Bosch LSU and some even have an EGT output. $300 will get the job done and you'll never look back. If you want to spend more money, get MS3.
                      • 87-325ic
                        • Apr 2006
                        • 1198
                        Originally posted by BeirBrennerE30
                        new ECU
                        megasquirt?
                        is it really that bad.
                        why is it i here such good things out of people who have done it?
                        or are these the ones who spend the 800+ on doing it right..
                        Whats my best option here then?
                        just swap a different ecu and chip it and be done with it? and start saving for a 24v swap? or a turbo..?
                          • 34839
                          there's nothing wrong with megasquirt but it's not going to go very well if you don't yet understand the stock engine management, which is a lot simpler. It's more something you get into after doing a lot of reading and deciding you want to play with/learn EFI.
                          I would swap ECUs first
                            • 34839
                            it will "get the job done" but have fun daily driving a car with no idle control and poor AE.
                            I wouldn't suggest MS1 to anyone at this stage, there's just no point, it's a dead end. at least MS2/MS3 share CPU architecture so development will continue to be strong.
                            besides MS3 isn't out yet, and isn't proven. It's waaay too complicated for a beginner to start with. They don't know about or need to deal with individually mapped injection angle tables. ;)
                            • matt
                              • 3731
                              MS3 is awesome. It's finally approaching where BMW was 15-20 years ago. :)
                              • 87-325ic
                                • Apr 2006
                                • 1198
                                haha awesome.
                                so i guess im staying with motronic. is the maf worth it though? its not much more than a new chip.... and it saves like 20 lbs up front...
