miller maf, or megasquirt?
  • SpecM
    • Oct 2005
    • 4531
    #46
    Originally posted by 87-325ic
    is there any reason i shouldnt replace the eccentrics with the head on the car?
    oh, they're very easy to replace in the car
    not the whole rocker, just the little adjusters
    1989 cirrisblau-metallic 325i
    • 87-325ic
      • Apr 2006
      • 1198
      #47
      yeah. thought so. i would be scared of dropping the nut into one of the oil returns though.
      i'll try that for my next valve adjustment, see if it holds better for longer.. the head is pretty new though. rebuilt not too long ago, but im not sure if the eccentrics are the problem.
      i do know two of them on the intake side are backwards, making it a bitch to get the proper tension on them.
      • SpecM
        • Oct 2005
        • 4531
        #48
        a wadded up rag shoved into the return helps
          • 34839
          #49
          replace the nuts and bolts too. Also check the rocker clips for wear and rocker side-side play.
          • NC325iC
            • Mar 2004
            • 6565
            #50
            I think there needs to be a N/A Megasquirt thread/subforum on here. E30tech has alot of MS info but it is mostly geared toward turbos. I know there are a few guys running MS on here with NA motors, and as i plan on going MS in the near future on my stroker, some starting points and more info would be helpful. the Megamanual can only get you so far.
            • einstein57
              • Jun 2007
              • 10780
              #51
              I have the diyPNP kit and i hit a wall at 4500rpm. Turns out my VR sensor is crapping out and the bosch ecu does a lot of compensating that ms can't. Try swaping that out to see if that clears up your issues.
              www.gecoils.com
                • 34839
                #52
                the stock ECU is just a lot less sensitive. Yours would probably work fine on MS1. Did you ever try the noise filtering?
                • der affe
                  Technical
                  • Dec 2005
                  • 8452
                  #53
                  +1
                  then i would not have to always bug nando with my MS questions. ;)
                  • 87-325ic
                    • Apr 2006
                    • 1198
                    #54
                    is this the crank sensor... ?
                    its a magnet, how can it really go bad? its either on or off. pulse/ lack of pulse.
                    • NC325iC
                      • Mar 2004
                      • 6565
                      #55
                      Originally posted by der affe
                      +1
                      thats my plan for the future, unless he starts a thread... EHHEEMM
                      • SpecM
                        • Oct 2005
                        • 4531
                        #56
                        the magnets don't go bad, but the area where the wires go into the sensor can (corrosion, breakage)
                        • 87-325ic
                          • Apr 2006
                          • 1198
                          #57
                          sounds good. ill check on that soon enough.
                          (im liking how nc folks are all over this thread)
                          • 87-325ic
                            • Apr 2006
                            • 1198
                            #58
                            so those who have had the Maf, is it worth the extra money besides just buying a chip?
                            or is most of the gain seen from the installation of the chip itself..?
                            • whatt18yahoo
                              • 619
                              #59
                              if you never go big turbo and just stick to light-moderate setups you'll be ok-ish but ideally megasquirt is going to give you any level of customization you could want. the miller stuff will allow some customization but it has limitations, it also has a few plusses namely pnp-ability but it is limited to plug and play-ability.
                              • HarryPotter
                                • Jan 2010
                                • 3642
                                #60
                                whaaa? :giggle:
                                John F. Kennedy
