Swap: S38 or S50B32
  • JoeMadoo
    • 936
    #31
    You could spend just a couple grand and turbo an M30...
    '86 E30
    '05 E53 X5
    '72 Firebird
    '10 Prius
    '03 Tundra
    • gearheadE30
      • Jun 2007
      • 3734
      #32
      didn't the race version of the S38/M88 end up around 375-400 chp? if the factory can't get more NA power out of it for a race engine, I doubt you'll be able to.
      Project M42 Turbo
      • Bimmerman325i
        • 6854
        #33
        They were around 400-450 iirc, but they were worked to high heaven. The guy with an E30M3 S38 I referenced is putting out similar power levels, but likely hit the same wall the factory did.
        2017 Chevrolet SS, 6MT
        95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
        98 M3/4/5 (stock)
        • Bimmerman325i
          • 6854
          #34
          Originally posted by whatt18yahoo
          dry sump helps
          Not a damn bit. Dry sump frees maybe 5 horsepower which gets eaten up by added pumping loss. The main point of a dry sump is to maintain oil supply in hard cornering.
          98 M3/4/5 (stock)
          • SpecM
            • Oct 2005
            • 4531
            #35
            bingo
            a muscle-car kinda magazine just did an article on the the new GM LS7 (Corvette ZO6), which has a dry sump motor, and showed how to retrofit LS3 wet-sump oil parts to use in swap cars. They dynoed it before and after on an engine (not chassis) dyno. It made 10 more hp with the DRY sump system. Really.
            1989 cirrisblau-metallic 325i
            • hugh jass
              • 2220
              #36
              dry sump helps
              seriously, do you ever give up?
              ______________________
              ex-Chief Operating Officer
              Blunt Tech Industries
              West Coast and Pacific Rim
              • 325ix
                • Aug 2009
                • 7783
                #37
                m60 v8? is that capable of 400 na?
                • Bimmerman325i
                  • 6854
                  #38
                  yea it's the S62 hahahaha. The M60 can easily put out 400 with some tweaks.
                  98 M3/4/5 (stock)
                  • xwill112x
                    • Jan 2009
                    • 4236
                    #39
                    go for the s65. comes with that much hp stock
                    420hp at 8300rpms :)
                    • Bimmerman325i
                      • 6854
                      #40
                      Apparently not, he deleted his posts though. Huzzah for quoting posterity.
                      98 M3/4/5 (stock)
                      • Bimmerman325i
                        • 6854
                        #41
                        Not based on the M60. ;)
                        Wicked motor though, OP do this one!
                        98 M3/4/5 (stock)
                        • BeirBrennerE30
                          • 2740
                          #42
                          swap in an s62 and your there... its not that hard of a swap and you have more torque than an s65
                          e30sport.net
                          '06 M3 Competition - 6-speed
                          '97 Range Rover Vitesse
                          • AndrewBird
                            The Mad Scientist
                            • 11898
                            #43
                            Only nerdy IT guys who are way to into BMW's do S38 swaps.
                            • madjurgen
                              • May 2005
                              • 1203
                              #44
                              How are you going to deal with 5L torque and skinny 245s?
                              Is he almost done?
                              As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
                              You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
                              • Alpina
                                • Oct 2004
                                • 838
                                #45
                                There is a 11x hp target for that,, and IMO not worth it
                                the engine pulls well,, 300 hp+ is maby no problem but to get in to the 400 hp range NA will cost a fortune i think,,
                                many owners have S/C their engine with 450 hp easy ,, but the cost is also high
                                Sveinbjörn Hrafnsson
                                E30 CABRIO V12 M70B50 ///
                                ALPINA B10 BITURBO 346 @ 507
                                E34 550 V12 JML
                                Finnish wisdom : If you want to Win,, hire a Finn
                                http://alpina.123.is/pictures/
