R12 to R134 ac conversion?
  • kronus
    • Apr 2008
    • 13032
    Found the receipt. With a new $700 r134a-ready compressor, it came to $1459.55 total.
    (which is about what I paid for the car, 2 years later :3)
    cars beep boop
    • e34john
      • Apr 2006
      • 3599
      How much R12 do you need? I might be up there at the end of the month.
      Otherwise drive down to TJ, just make sure they don't fill up your system with propane.
      • gone002
        • 880
        wow 1400$ is a grip!!!....more than the car is worth.
        i never heard of freeze12...ill have to look it up,
        no conversion necessary?
        and sweaty balls on a date = no puss! =(
        bimmerboltsandparts.com
        bring back the neeked broads!!!
        • tjts1
          • May 2007
          • 1851
          Just get Duracool. Best $20 I ever spent. Or drive to TJ and get it refilled with R12. Don't get shot.
          • Naplm00
            • Nov 2008
            • 1573
            Or just run the synthetic 134a+ that you can get at most autoparts stores. IT has a lube built in and works fine with older systems.
            Its like $20 a can.
            I put this in my eta and it was cold for 2 years until i scrapped it. all you need are the adapters to fill it, they are usually in the same isle and about $15 bucks.
            GETTING STARTED Explore our products for R-12, R-134a, and R-1234yf vehicles and discover just how easy it is to restore your vehicle’s cold air yourself.” Explore More Port Finder Already have the product? Search our database to find the location of your car’s port. Search Database HOW-TO VIDEOS See how easy it is to recharge...
            88 325ic ~~~> Rusty and ugly
            85 E ~~~> RIP
            • hugh jass
              • 2220
              r12 is getting cheaper and cheaper actually. there are fewer and fewer cars out there that run r12. you can find cans on craigslist, and most shops still have it. don't convert to r134 unless you have to, it sucks compared to r12.
              for example:
              ______________________
              ex-Chief Operating Officer
              Blunt Tech Industries
              West Coast and Pacific Rim
              • guibo09
                • Dec 2008
                • 834
                for example:
                http://sacramento.craigslist.org/pts/1630016673.html
                wow wasnt r12 like 100$ a lbs not too long ago?
                i would also like to refer people to this thread and the two useful PDFs there: http://forums.bimmerforums.com/forum....php?t=1225303
                notice in the second PDF that r134a systems blow COLDER than r12 systems. Im not sure if this includes retrofitted systems also however.
                90 E30 325i
                • tjts1
                  • May 2007
                  • 1851
                  It doesn't. Retrofited R12 to R134 systems are pathetic.
                  • hugh jass
                    • 2220
                    yes, r12 condensers aren't really designed for r134. you really have to replace everything to efficiently run r134 in an older car, and that costs a crapload.
                    • boom-monkey
                      • 1104
                      Quoted from experience?
                      My car is retrofitted, in Florida summers 95 degrees and 80% humidity I'd have to adjust the heat cause it was too cold.
                      • 619E30
                        • 1753
                        Freeze12
                        Originally posted by audiquattrot
                        bimmers b4 b*tches....remember that.
                        1990 Alpinweiss 325i - secret 500whp build
                        2000 Audi S4 B5 Laser Red
                        1990 Nissan 240sx - Drift Missile
                        2006 CBR600RR
                        • gone002
                          • 880
                          yeah i wont be driven to TJ unless in need a burritto and an open gunshot wound!
                          i looked everywhere for r12 no one will touch the stuff here in cali
                          for 50$ freeze 12 looks like the sheet!
                          how come none of the shops i talked to offered it?
                          • gone002
                            • 880
                            for example:
                            wow dude at f**kin around ! he hit me up already..how many cans do i need?
                            • 619E30
                              • 1753
                              If you come down to sd I can do it, I have a bunch. 10 bucks a can
                              2006 CBR600RR
                              • 619E30
                                • 1753
                                I only needed 2 cans
                                2006 CBR600RR
