friends 88 e30 is pulling hard left on highway
  • idanity
    • Jun 2006
    • 775
    want to post in most visible room
    the suspension room is devided into at least 2 more rooms that this post would fit, so instead of multiposting, i put the general room to help.( could be Wheels & Tires, Brakes, Subframe & Arms, Springs, Shocks, Sways & Steering, or all.)
    and he needs help asap from anyone w/any experience of this.
    a friend in a 88 325ic w/40k original miles called me, and is on a road trip a few states away.
    asked to post- any help and i can send an SMS.
    issue;
    car drove fine 3 weeks ago, then had it aligned, (4 times total since the 1st alignment)-
    aligned at firestone - (twice) said they want to replace control arms (both were already replaced)
    aligned at dealership- master tech said "unsure"
    - swapped wheels/ tires with Peerless's spare set, ( no change- so this is the chassis)
    i suggested
    - rack
    - frame
    - string method
    - swap front to rear wheels (this was a week ago tho. before he swapped a spare set in Cali)
    - struts
    - still swap front to rear wheels,
    - tie rods
    etc.
    now, after many a professional has looked at this, he states its getting worse.
    what can cause this issue that no-one else can find (bmw master tech at dealer, firestone employees, and other "pros" ) ?
    any ideas ?? (that can be accomplished on the road )
    3 pedal club
    200,k+ club
    cabrio club
    port-matched- polished- purring www.BMWpark.org
    </div>
    linux since 1999
  • nrubenstein
    • 3148
    What does the rear axle geometry look like? If the front has been aligned so many times, it's probably "fine." an on the road fix might be to screw with the front tie ros until it stops pulling. Just try to turn each side by the same amount.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • moatilliatta
      • 6152
      low tire? or radial pull, try swapping the two front tires side to side if they are not directional.
      @Zakspeed_US
      • Naplm00
        • Nov 2008
        • 1573
        can also be a draggin brake caliper, most likley its the tie rods
        88 325ic ~~~> Rusty and ugly
        85 E ~~~> RIP
        • idanity
          • Jun 2006
          • 775
          thanks
          he stayed in a scrote-tell instead of driving/ crashing at night.
          good points to swap left/right too, and thanks,
          he did say the brakes are not draging, but its a great point, even a rear brake would cause that.
          he is meticulous, so i think ultimately it has a frame issue that was corrected by tweaking, and the recent alignment into specs screwed it all up
          (car had damage when he bought it, front end stuff too. so very likely imho)
          so, i also included to re-align using the string method
          3 pedal club
          200,k+ club
          cabrio club
          </div>
          linux since 1999
          • JUMPNYC
            • 519
            Swap tie Rods Check all bushings on control arms get the front wheels off the ground and make sure there is no play in the wheel, like it has play and can move side to side when steering is at lock. Is it power steering? Check the steering box as well.
            • bimmer_E30
              • 5001
              Bent Frame?
              happend on my old E21!
              Originally posted by e30e
              • idanity
                • Jun 2006
                • 775
                didn't know the tie rods could be swapped, but adding that to the list.
                main issue remains, at least 4 separate shops tried, and all fails
                so,
                im thinking it is the frame after all, and the 1st alignment screwed up a custom alignment to compensate.
                but thanks
                passing it on.
                3 pedal club
                200,k+ club
                cabrio club
                </div>
                linux since 1999
                • e30:)
                  • 728
                  when i bought my car it pulled real hard one way and it was a bent control arm...
                  • idanity
                    • Jun 2006
                    • 775
                    both control arms are brand spanking new from dealer.
                    thanks tho.
                    3 pedal club
                    200,k+ club
                    cabrio club
                    </div>
                    linux since 1999
                    • nrubenstein
                      • 3148
                      A proper alignment machine will compensate for a bent frame.
                      Strings will not.
                      I still want to see an alignment sheet.
                      • idanity
                        • Jun 2006
                        • 775
                        thanks everyone.
                        turnes out, the SPRING is BINDING.
                        never heard of that before
                        but one side is about 2 inches lower, and when he saw his spring, he stated the coils are touching each other in spots.
                        so, maybe its cracked, or broken, or the perch or top bearing are shot.
                        how that happened during an alignment, i may never know. but its one thing i did not think of.
                        pix requested, and will post if i get any hands on.
                        3 pedal club
                        200,k+ club
                        cabrio club
                        </div>
                        linux since 1999
                        • evil_twin
                          • Nov 2007
                          • 2965
                          Originally posted by idanity
                          thanks everyone.
                          Honestly, If the people you were taking the car to were good technicians, they would have measured the vehicles ride height before doing the alignment. Thats one of the preliminary checks when you get the car on the rack...
                          Poor job on the technicians that did the job.
                          Paypal: vdang5@gmail.com
                          Delta Auto Care
                          2875-C Towerview Road
                          Herndon, VA
                          703.435.1375
                          My Feedback Thread: Evil_Twin
