Reason not to Buy and Mcoupe - there is only one
  • DrMcDave
    • 1793
    The idiot bmw trim engineers really dropped the ball on this car. My RSM's are shot so I figured I'd replace them. I figured I've done e30 ones before and it was simple so why not do the coupe. The rear suspension is the same.
    So I get online to pull some directions about removing trim only to find out you have to remove 25 pieces of trim.
    So after 1.5 hours of trim removal I finally explosed the RSM's. Luckily rogue engineering designed RSM's that mount from the bottom so I never have to do this again.
    • 34844
    but hey.. you have an M-coupe. It can't be that bad, right? :)
    • DrMcDave
      • 1793
      lol not it's not bad, but I was very annoyed while doing this yesterday. I haven't done the actual RSM's yet but once they exposed it's simple as you know.
      • BenM
        • 2184
        +1. But seriously, E34 Tourings are very similar in regards to the amount of trim that needs to come out when doing the RSM. There are probably a few less pieces and not as crowded workspace though.
        Originally posted by BillBrasky
        E36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
        1991 318i Alpine II - S50/5-lug swapped - track car
        1989 325i Cirrusblau - Daily
        1970 2500 - Malaga over Grey Cloth
        2012 F350 6.7PSD
        • DrMcDave
          • 1793
          I guess there isn't an easy way to trim out a hatch/touring setup
          • daniel
            • 6703
            wow, good luck putting everything back in the right way!
            but i'd have to agree that that is the only downside to owning an M coupe.
            http://instagram.com/dslovn.drives
            • wrh3
              • 3
              The Z4M Coupe is not any better.....and I went with Rogue RSMs when I changed out my suspension for the same reason- only have to do it once.
              Bill
              2007 M Coupe, 2008 M3, 1986 325es
              www.billswebspace.com
              • DEV0 E30
                • Oct 2004
                • 8904
                Yeah, not looking forward to this.
                • bataangpinoy
                  • Jul 2008
                  • 1636
                  things would really stink if your wrench slipped and it went through that subwoofer.
                  My feedback:
                  http://www.r3vlimited.com/board/showthread.php?t=186328
                  http://e30tech.com/forum/showthread.php?t=74911
                  Instagram:
                  @gears_n_glory
                  @functionmotorsports
                  • dinanm3atl
                    • Feb 2007
                    • 7305
                    Yup. One 'flaw' is how they are sort of put together. Get the rogue or similar design for future work :)
                    • DrMcDave
                      • 1793
                      I've got the rogue for sure.
                      DEVO E30 - it looks hard but it was actually really easy to do. At no point was I stressed that I might break something. There are only about 4 of those snap in type fasteners that cause breaking.
                      • dirty30
                        • 3111
                        Ever take apart an e46 touring for rear shock mounts? Yep. Same thing.
                        • Drew325is
                          • Oct 2004
                          • 520
                          I bet when you're finished the RSM replacement, you'll be all pissy...then you'll step back, look at the coupe and say "aaaaawwww I can't stay mad at you".
                          • RickSloan
                            • 2401
                            and i thought m roadie ones where hard, doing them from the front seat and all
                            Need Illustration or Design work? www.robbiebyerly.com
                            • Lunner
                              • 222
                              Yay, one maintenance related reason I'm glad to own an e30 iC. RSM's are under the boot lid, and not covered by nothing :D
                              87 325iC 90 325iC 88 325iC 87 325i 87 325iS 87 325eS
