Name that failure! (HELP!)
  • Naplm00
    • Nov 2008
    • 1573
    Well driving to work today my CEL came on.
    Here are the symptoms:
    Stomp test reveals Code "1223" coolant temp sensor
    Car hesitates under accel and hessitats heavily under hard accell
    wonky idle
    Will drive fine when under 3-3.5k as long as you are really really easy on it.
    Well im goin to check the coolant temp sensor and try to replace today. Any other suggestions? Before the stomp test I was thinking Crank Position sensor.
    EDIT: I'm at work and dont have access to my Bently andone have resistance readings for the coolant sensor(are they different and different temps?) I have a meter here at work.
    88 325ic ~~~> Rusty and ugly
    85 E ~~~> RIP
    • 34844
    I'm guessing.... CLT sensor?
    • Naplm00
      • Nov 2008
      • 1573
      yea, ill be repalcing that, but when mine failed on my old car the car did not act like this
      85 E ~~~> RIP
      • PeaveyBassist
        • Sep 2004
        • 3511
        Coolant temp sensor
        RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
        Welcome e30 (brilliantrot '90 325is) 12/23/06
        DaveCN = Old Man
        My signature picture was taken by ME! Not by anyone else!
        If people keep quoting me in their sig, I'm going to burn this motherfucker down.
        • Naplm00
          • Nov 2008
          • 1573
          Ok,
          Where does the CLT wiring terminate? I want to check for a short in the wiringin as well
          85 E ~~~> RIP
          • Naplm00
            • Nov 2008
            • 1573
            Nevermind
            85 E ~~~> RIP
            • Naplm00
              • Nov 2008
              • 1573
              C191 is the main engine to chassis plug correct?
              If i measure resistance from pin 1 on the CLT sensor plug (br/red) wire to pin 1 on C191 I should get little to no resistance, or a tone on the diode test correct?
              If that tests out ok, then testing from the connector to Pin 45 on the motronic connector should produce the same results..
              Pin 2 shoud have little or no resistance to ground (Br/OR)
              EDIT: C191 is the injector plug under the intake manifold, im goin to go spary some WD 40 in the bad boy right now
              is my logic flawless?
              85 E ~~~> RIP
              • Naplm00
                • Nov 2008
                • 1573
                OK well i ohmed out the circut
                I am ok everywhere except for from C191 to the ECU connector on PIN1 to PIN45
                I am getting 13-14.5 Mega Ohms...
                If I am reading the diagram correctly..that should be a straight shot with little to no resistance correct? I am measuring with the ECU disconnected from the plug directly and fron the car side of the disconnected C191 plug.
                Besides opening up the harness to repair this line is how else can I quixk fox this unitl i get home later? run a jumper?
                where the heck is George graves?
                85 E ~~~> RIP
                • 2002maniac
                  • 4260
                  Try replacing your coolant temp sensor
                  • Naplm00
                    • Nov 2008
                    • 1573
                    Dont think its the sensor, after finding that open connection, i think its the C191 plug
                    Ive never taken apart one of these cannon plugs, im guessing it just comes apart fromt the rear?
                    85 E ~~~> RIP
                    • Naplm00
                      • Nov 2008
                      • 1573
                      ended up being the c191 connector, took it apart and it had a corroded wire...replaced the pin and its Aok now!
                      85 E ~~~> RIP
                      • txtorquemade
                        • 1758
                        hummm.....could be the source of my idle, ticking problem????
                        sigpic 1987 325is
