crap! how long can i ride on a bad clutch bearing?
  • downernsp
    • Mar 2008
    • 1932
    If you can do the work just do it why test it not smart IMO.
    • HarryPotter
      • Jan 2010
      • 3642
      Ya clutch job and all the other goodies are in my near future if I actually start getting some MOTHERFUCKING hours at work.
      John F. Kennedy
      • Wh33lhop
        • 11705
        So what the hell do you replace when the car makes the noise when the clutch ISN'T depressed? When I push it in there is no noise, but when I let it out it gets a little rattly.
        If you really want, you can disassemble the trans and replace the input shaft and layshaft bearings. But most people call that "Getrag rattle" (ZF320s do it too) and live with it.
        Also, some report decreased input shaft rattle after putting Redline in their trans. You may want to give that a try (didn't work for me, but your mileage may vary).
        paint sucks
        • AndrewBird
          The Mad Scientist
          • 11898
          Originally posted by 84E30
          u got change the clutch bearing and throw out bearing
          No. You need to learn to read.
          I'm pretty sure James had this noise even after rebuilding his tranny. I think it is just something that you have to deal with like Wh33lhop said.
          • Jparkr
            HR Admin
            • Jan 2006
            • 3494
            are you talking bout criv? we didn't rebuild his tranny, we just changed the input shaft bearing. It did not fix the "getrag rattle"
            1987 PRO-3 car /1990 325is (2.7i Concours)
            • Devil Inc
              • Jan 2008
              • 802
              I melted a TB in mine, replaced it and all was good. Started as a slight grind/rattle, then that turned into a full on squeal as well as not wanting to change gears. I just replaced the whole clutch assembly and all was good.
              • mikeedler
                • 6707
                WTF is a clutch bearing?????????
                are you trying to say the pilot bearing in the end of the crankshaft?
                ohh, and I wouldn't ride too long on a really noisy trans.-- when it does decide to blow apart it WILL take out a bunch of stuff with it- that wouldn't have needed to be replaced if it was done before it comes apart.
                • 84E30
                  • 456
                  my bad ya i meant to say is pilot bearing..
                  Check out my Insurance Thread
                  http://www.r3vlimited.com/board/showthread.php?t=164190
