Engine Clutch Fan Delete
  • 88SuperETABD
    • Apr 2009
    • 911
    So, I dunno if my gauge is wrong, but my car never gets as warm as it did when I had the A/C in it. And before my 2.7i. My needle rarely makes it far from outside the blue. With the AC stuff missing my radiator gets a lot! more air flow. I understand why its cooler...how much does this fan help out with temp? Also any benefits of deleting it? other than a cleaner engine bay?
    (SOLD) 1988 327i Build Thread: http://www.r3vlimited.com/board/showthread.php?t=155086
    1970 Gruppe 2 2902 M20 Turbo Build: http://www.r3vlimited.com/board/showthread.php?t=373891
  • ubernasty
    • Jan 2009
    • 2749
    maybe your thermostat is just stuck open. when i took the ac out of my eta is didn't run noticeably cooler
    • Rennsport
      • 2139
      Your thermostat has failed, I don't have an engine clutch fan (no room) and my engine never runs hot.
      m106 1990 e30
      e36 daily
      e32 cruiser
      • Wh33lhop
        • 11705
        The thermostat should regulate the operating temp of your car, not the radiator/fan--at low temps the thermostat shouldn't be passing coolant through the radiator anyway. I'm with the others--stuck thermostat. Does it take longer to warm up as well?
        paint sucks
        • 88SuperETABD
          • Apr 2009
          • 911
          nope
          My car warms up normally...my engine will say its cold even after a 2 hour drive. Worried it running colder, if it even is, could cause damage after a while.
          • Danny
            • 14216
            This sentence is contradicting.
            • Wh33lhop
              • 11705
              Yep. But it's pretty obvious the thermostat is the clear solution.
              Do it. It's not that hard of a job.
              paint sucks
              • noE30
                • Jun 2008
                • 2260
                whats needed to delete the clutch fan? convert to electric??
                Flickr
                @michael.colby on Instagram
                "All he needed was a wheel in his hand and four on the road"
                • Danny
                  • 14216
                  What's your actual name, Wh33lhop?
                  I tend to agree with you quite a bit and would hate to keep calling you Wh33lhop, its a pain to type.
                    • 34839
                    you want to delete your fan, I actually want to go the other way, ditch the electric and use a standard clutch fan. lol
                    • hoseklamp
                      • 214
                      Japandrew? Is that you?
                        • 34839
                        no, I'm just getting a bit tired of relying on the electric fan all the time. the clutch fan will keep the engine temps more stable, and it shouldn't make any difference in power. it might even be lighter..
                        plus I'm not cutting my subframe to make it fit. ;)
                        • Naplm00
                          • Nov 2008
                          • 1573
                          I ditched my clutch fan when I swapped to the M42 rad. I'm using a flexalite 16in pucher upfront where the AC stuff used to be. Works great
                          88 325ic ~~~> Rusty and ugly
                          85 E ~~~> RIP
