horn
  • mikes325is
    • Jan 2010
    • 32
    horn
    My horn will not work why
  • McGyver
    • 4636
    you're out of turn indicator fluid. e30s have them on the same circuit.
    • mikes325is
      • Jan 2010
      • 32
      no man, i put a new relay and a fuse i even try new horns still will not make a sound i took the steering wheel off to see if it was the contacts it all in great shape, it use to work fine and it stop working about a month ago
      • Chabs
        • Jan 2010
        • 538
        maybe the button is broken
        Josh
        http://www.r3vlimited.com/board/showthread.php?t=159843
        • mikes325is
          • Jan 2010
          • 32
          no my car has 3 buttons on it and they all work before
          • raafhimself
            • Dec 2008
            • 451
            maybe your finger is broken
            • 619E30
              • 1753
              Maybe some where the wiring got messed up
              Originally posted by audiquattrot
              bimmers b4 b*tches....remember that.
              1990 Alpinweiss 325i - secret 500whp build
              2000 Audi S4 B5 Laser Red
              1990 Nissan 240sx - Drift Missile
              2006 CBR600RR
              • Raxe
                • 5346
                maybe you're deaf
                • trackjunkie21
                  • Jan 2010
                  • 3962
                  do you have a battery connected?
                  Originally posted by Wh33lhop
                  VANOS: sometimes you just need to go full retard.
                  • mamzak
                    • 883
                    Originally posted by Raxe
                    maybe you're deaf
                    All girls fuck but not all girls fuck around with combustion engines.
                    • threlevenguy
                      • Dec 2006
                      • 1057
                      maybe you're deaf
                      • TomSuddard
                        • 179
                        I'll bite.
                        1. Buy Multimeter. You probably don't know what that is, so click here:http://tinyurl.com/ofyvzn
                        2. Check continuity between contacts on the steering wheel with the button pressed/ unpressed. This will test the switches. "It worked before" doesn't mean it works now. The Challenger Space Shuttle worked before, too.
                        3. If there is no continuity with the button pressed, viola, you need a new switch. If there is, put the wheel back on.
                        4. Check for continuity further and further away from the wheel in the circuit. You might have to refer to a wiring diagram (it's like a treasure map, only with colored lines) to find the right wires for the horn circuit.
                        5. When you no longer have continuity when the button is pressed, you've found the break in the circuit. Fix it.
                        6. Normally I wouldn't write this, but you seem like you'd do it. Don't fix the break with any of the following:
                        bubblegum
                        epoxy
                        bondo
                        cardboard
                        your brother's cousin's sister's mom's secret patching stuff
                        spit
                        paperclips
                        bubblegum (again)
                        duct tape
                        JDM parts.
                        There you go. Easy horn repair.
                        • Be30mer
                          • Jan 2010
                          • 1121
                          1. Buy an airhorn. ~$8
                          2. Roll down window
                          3. Depress release valve on airhorn
                          4. Stop posting dumbass questions on here.
                          You are lucky your Dad didn't pull out and leave you on the passenger side seat.
