Shipping a Motor from Europe
  • moatilliatta
    • 6158
    What is the most econimical way of doing it. Kinda looking for a hook up aslo. Looks like UPS, DHL, or FedEx Sea Freight. Motor is comming from Lithuania to Indiana / Kentucky. There is a port in klaipeda, Lithuania to ship from.
    Thanks,
    zach
    @Zakspeed_US
  • lifeiskaos
    • 1709
    In before comments about kenika's bilsteins from Lithuania.
    I have no idea how to get an engine overseas cheaply, sorry.
    • chadthestampede
      • Jul 2008
      • 3601
      fffffffffffuuuuuuuuu
      Originally posted by LJ851
      Feedback
      • Joe318is
        • Sep 2005
        • 6451
        what motor is worth shipping from overseas?
        Originally posted by vlad
        • FredK
          • 14763
          M40
          • Nygdup
            • Jul 2006
            • 418
            Check directly with air frt shipping services. Weights between 200lbs and 500lbs can sometimes fall into a gray area where air freight is cheaper than ocean freight because of the difference in minimum charges.
            Pilot Air would be a good place to ask. Chances are they can arrange a door to door pickup and delivery if needed. I do this for a living. If you need more help shoot me a PM.
            -Rich
            • matthugie
              • Mar 2004
              • 1810
              S50B32 is the only one I can think of. If that's the case then the OP will have other issues with customs since it wasn't available for the USDM. There's a fairly extensive thread on importing engines somewhere, I think in the FS section. There isn't talk about cost though, just procedures, but it still might be helpful.
              88 325is - S52 powered
              Originally posted by King Arthur
              We'll not risk another frontal assault, that rabbit's dynamite!
              • quickervicar
                • 1197
                Check around your area for an international freight broker. This is what they do for a living. In a city the size of Louisville there's got to be at least 3 trying to beat each other up. They should give you a very competitive rate for freight door-to-door. Customs & duties will fall into your lap, too.
                Explain that you simply wish to import an engine to the states to use in your father's gen-set for his cabin. A BMW engine is the only one powerful enough to get the job done. ;)
                • george graves
                  • 20003
                  Originally posted by Matt-B
                  • Rigmaster
                    • 3464
                    You need the services of a "Freight Forwarder"
                    If you want to try to do it yourself, you'll be in for a MAJOR PITA and a bunch of stuff that can cost you $$ if you do it wrong. Freight Forwarders basically act as your agent when shipping something, and make $$ doing so. They typically have discounted shipping rates with airlines, ocean shipping companies, etc and they can make money on your shipment without costing $$$ compared to you trying it yourself.
                    • moatilliatta
                      • 6158
                      Thanks everybody for their ideas, I go over them and see which best works for my scenario.
                      PS its for my e34 touring.
                      As of now...
                      m57b29 with wiring harness , ecu, and accessories
                      GS5-39DZ or GS6-29DZ
                      E34 2,64 rear end or a E39 2,35 Rear End if the gears with fit inside a e34 case
                      Probably make custom drive shaft.
                      @Zakspeed_US
                      • Farbin Kaiber
                        Lil' Puppet
                        • 29502
                        lookx torque-y.
