What oil weight is everyone using?
  • rThor432
    • Feb 2007
    • 3907
    #31
    I run 15w50 Mobil 1 in my '85 eta and S52 car. My eS gets 10w60 because it's a 'sport' eta ;)
    • Sailor37
      • 985
      #32
      10w-40 Mobil1 High Mileage. Took some "before" pics of the valve train to see if it cleans up the alley at all. Going to extend drain intervals to about 5000 to 6000 miles.
      • richardkeith97
        • 1693
        #33
        mobil 1 10/30 synthetic high mileage. 225k miles. doesn't burn or leak a drop of oil. they don't carry the 10/40 in a jug here. should i switch to 10/40 anyways?? i autox also. dk if that makes a difference?
        • richardkeith97
          • 1693
          #34
          i'll spend the extra $$ if its going to save my motor!!!
          • Atreus
            • 1846
            #35
            castrol only.
            i normally run 10x40 or 20x50, depending on the season. Castrol GTX-highMileage+castrol syntec FTW.
            I used the syntec in the m20 from like january, runs real good, coming up on my 5k oil change. gonna see how clean the head is too when i do it.
            quick question, because im having a brain fart right now, BUT:
            cold temp=lower weight oil to help with viscosity right? (10x40)
            hot hot hot summar=higher weight oil? (20x50)
            or do i have it backwards...
            1991 325iC - Mauritsblau sumthin metallic blue. DEAD
            1992 525i - Silber sumthin sumthin metallic- Rolling again, needs suspension/wheels/brakes/paint.... Fuck you A4S310R; BEAT YOU.
            1989 325i - Cirrusblau Metallic sumthin sumthin-project - trying to clean up the interior(done), then the body, then a 5spd, then suspension, then..... - [Stolen :| ]
            1991 325iC - Calypsorot Metallic
            1994 540i - Granitsilber
            Originally posted by scabzzzz
            I've had blunts cock in my mouth, but I'm not gay.
            • kamotors
              • Nov 2007
              • 7102
              #36
              castrol 20w50
              7speedshop.com
              • Turd
                • 185
                #37
                Ran Valvoline VR-1 5w30 in my M20 before it kicked the bucket. Castrol Syntec 10w40 in my M50.
                • Naplm00
                  • Nov 2008
                  • 1573
                  #38
                  Originally posted by ldsbeaker
                  Coincidence?
                  dont think so, filter is made in the same factory
                  88 325ic ~~~> Rusty and ugly
                  85 E ~~~> RIP
                  • whatt18yahoo
                    • 619
                    #39
                    mobil 1 full syntheic 5w30 with mobil1 filter. changed every 6,000 miles. (i drive mostly highway miles) and even by time it's less than 10% city driving.
                    • SpecM
                      • Oct 2005
                      • 4531
                      #40
                      you people and your 5w30 and 10w30
                      way way too thin
                      1989 cirrisblau-metallic 325i
                      • Lunner
                        • 222
                        #41
                        Stock M20's burning oil is NOT a cause for a full rebuild, or haven't you guys been reading your Bentley?
                        If it's extremely excessive, your valve guides could be worn, so at most a head refresh would be in order.
                        And again, Bentley, 10w30 is way too thin.
                        (I used castrol high mileage 20w50 until my rebuild, now I use Red Line 20w50 the 6 hottest months of the year and 10w40 the coldest 6).
                        87 325iC 90 325iC 88 325iC 87 325i 87 325iS 87 325eS
                        • bimmer_E30
                          • 5001
                          #42
                          i used 5w30 in my old eta and i was burning it like crazy! these cars need thick oil.....20W50 or GTFO.
                          i am wondering what oil weight i should be using this winter when it dips to -40 tho :S
                          Originally posted by e30e
                          • Philo
                            Ich esse kleine Kinder
                            • 3334
                            #43
                            Rotella T 15w40. :) Diesel oil. The extra detergents keep my engine clean as can be.
                            Disclaimer: Do not use this oil unless the engine is new.
                            -tim
                            Originally posted by Jordan
                            I like the stance
                            • mrsleeve
                              • Mar 2005
                              • 16386
                              #44
                              really I have never ever heard of any negative consequences to running a API CJ-4 rated engine oil in gasser. Hell the extra zinc content and extra resistance to viscosity loss with extended change intervals and extreme temp operation also has a high resistance to oil sheer as well its a good thing. This is why I cj-4 oils in almost everything all though I dont run Rotella I run Delvac from Mobil one
                              Tell me what am I missing.
                              Originally posted by Fusion
                              William Pitt-
                              • Holland
                                • Nov 2008
                                • 7176
                                #45
                                I am running Rotella T 15w40 in the M10. 89 thousand miles and it seems to be doing fine so far. I agree with mrsleeve, what am I missing because that's why I'm using it in the first place.
                                Originally posted by DEV0 E30
