Automatic crazyness
  • Zues
    • 145
    Automatic crazyness
    I have a 90 m20is with an auto and its never shifted over 2500 rpm when left in drive even with the throttle barried. Ive heard that many e30 are like that and that its an economy thing.
    90 m20is
  • whodwho
    • Jun 2008
    • 1547
    Nope, It should let it to almost redline. Check your kick down cable adjustment.
    My M20 Frankenbuild(s)
    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
    • kenika65
      • Aug 2007
      • 1336
      kick down cable for sure
      1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
      1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
      • Zues
        • 145
        Thats the cable next to the throttle? Ive messed with that and all it does is make the car shift harder. Am i missing something?
        90 m20is
        • Be30mer
          • Jan 2010
          • 1121
          drive it like a manual if it really bugs you.
          You are lucky your Dad didn't pull out and leave you on the passenger side seat.
          • kamotors
            • Nov 2007
            • 7102
            or just fix the problem? an auto should rev out to 6k in every gear simply by flooring it.
            7speedshop.com
            • Be30mer
              • Jan 2010
              • 1121
              I change my mind. Just convert it to manual.
              • siggy
                • Oct 2009
                • 327
                There is a kickdown switch that you can adjust, it is in the drivers footwell under the gas pedal. It adjust up& down similar to a clutch stop. Bentley goes over the procedure.
                  • 34839
                  it's not a switch, it's just a detent, but if the kickdown cable is adjusted properly it works sort of like a switch.
                  • Zues
                    • 145
                    I have all the parts for a manual sway with the exception of the shifter assembly so thats in progress. Meanwhile I do drive it like a manual, but this has always been buggin me. Cable next to the throttle only seems to adjust the firmness of the shift. My other thought is that I have an ecu out of a manual. Could this be that case?
                    90 m20is
                    • Zues
                      • 145
                      Hardcore!! so I adjusted the shiz out of that cable and now the shifts are right. However it chirps into 2nd at about 3200. I probably wont leave it this way for fear of wearing out the tranny.
                      90 m20is
                        • 34839
                        the ECU doesn't do anything with the tranny on E30s, auto/manual are the same.
                        • kamotors
                          • Nov 2007
                          • 7102
                          I emailed Mark a couple years ago and Mark D told me the chips were different for the auto's and manuals. Although I've run the regular chip and the "automatic" chip and felt no difference. The "auto" chip he sent me was for an e34 525i.
                          7speedshop.com
                            • 34839
                            Sure. It might have a different idle speed or something but it doesn't control the transmission at all.
                            • bmwstephen
                              • 2463
                              how does the cable just get miscalibrated and mess up like that?
                              could messing with the throttle body cause this problem? My car had this rpm issue onyl after I had reinstalled my head, manifold etc
