Pressure washing question
  • alwaysclean
    • Jan 2010
    • 1120
    I searched with no results.
    I wanna wash my engine bay, and motor. what cant get wet ?? I wanna be able to leave the car wash.
    thxx.
  • Norwegiandane
    • 110
    Don't pressure wash. Low flow or steam only.
    High pressure can blow water past seals and weak gaskets.
    You're entitled to your own opinions, not your own facts.
    • Raxe
      • 5346
      Everything is okay to wash except the alternator, try to keep as much water away from that as possible. Other than that go to town. Never a good idea to get too close to the engine with high pressure, stay 2-3 feet away.
      • alwaysclean
        • Jan 2010
        • 1120
        So plugs and ignition coil getting wet is no prob?
        • pureaudio
          • 1123
          I have pressure washed the engine bay of every car I have ever owned, never had a single problem. Remove the air box and duct tape a plastic bag over the intake boot, I don't blast the alternator directly but never needed to cover it.
          • 5KWattson
            • Apr 2009
            • 809
            COP's + water = missfire! on a 24v atleast blow them off with air or dont get them wet at all
            "God created turbo lag to give V8's a chance" Taylor D.
            • sharky
              • Jan 2005
              • 2672
              fusebox
              • alwaysclean
                • Jan 2010
                • 1120
                Thx i just didnt wet my alternator and i was fine, It looks great !
                • alwaysclean
                  • Jan 2010
                  • 1120
                  Everything worked out a hour and half at the carwash and i have a spotless engine bay!
                  • markseven
                    • Sep 2006
                    • 5327
                    I spray it down with low, low water pressure. The coat everything with Simple Green automotive degreaser. Then wipe down with an old microfiber hose with low water pressure. Dry everything with a leaf blower.
                    I Timothy 2:1-2
                    • alwaysclean
                      • Jan 2010
                      • 1120
                      I keep simple green, gloves and 20 terry clothes in my trunk , exactly what i did but minus the leaf blower. Im a clean freak
                      • txtorquemade
                        • 1758
                        Ive pressure washed all my engine bays, never had a problem. I try to keep the fuse box dry but I dont obsess over it. No problems. Always starts. <shrug>
                        sigpic 1987 325is
                        • AndrewBird
                          The Mad Scientist
                          • 11898
                          If the cover on the MAF has ever been removed, water can get in and wreak havoc. Also getting water in the distributor cap will make the car not run, but the e30's is pretty well shielded. The alternator is fine getting wet, as long as you aren't spraying it down with the engine running. Fuse box like everyone said, probably wouldn't be the best to spray either, but as long as you don't hammer it with the sprayer, you should be fine.
                          • woodisgood
                            • 1087
                            Any danger spraying down a hot engine? This always freaked me out..also I have wondered about cleaning brakes while hot, I have ceramic pads....
                            • Chabs
                              • Jan 2010
                              • 538
                              i plan on washing my engine bay as well. I was told to cover up the air filter. alternator and fusebox as well?
                              Josh
                              http://www.r3vlimited.com/board/showthread.php?t=159843
