325i 885 head modification to increase compression
  • dougs87325is
    • 32
    Stroker SUPER GHETTO 2.7
    Im in the process of swapping my 86 eta 2.7 block to put in my 87 325is.Im thinking on trying to have the combustion chamber welded and filled in where the dome is on the i head. I think this is very doable. Im wondering has this ever been done to a 885 swap, all stock ETA parts?
    I have had heads welded and they are solid.
  • Mossman
    • Apr 2006
    • 1961
    ughhhhh what about where the valvey things are? I think a better option, not sure if it's good, but sounds better to me, would be a pretty considerable deck, I think 0.040" nets you a 1 point bump in compression. So yeah....deck a lot and if necessary get valve reliefs milled into the pistons.
    • dougs87325is
      • 32
      Forgot to add that I still want to Turbo Later on. I want to try and see how much hopefully reliable horsepower I can get when its all put together.
      • 1craze30
        • 1224
        get an m50, then turbo. head work is $$$$$$
        • evandael
          • Oct 2009
          • 2881
          If you want tarbo, just live with the low compression until then. I think its best to just leave the combustion chamber alone, sometimes just increasing the compression ratio doesn't have the desired effect.
          Messing with the "squished" area in the combustion chamber can result in an engine that runs worse, pings badly, or just generally does not generate power as effectively as leaving it well alone.
          • dougs87325is
            • 32
            I want to try this, I think it might be 100 bucks to have the areas on sides of chambers welded( where the dome starts), not much material needed, increase cc of chamber. Then you grind it as even as you can get it, mill it. Im thinking when I turbo it, I can come back later and grind that material away.
            • SpecM
              • Oct 2005
              • 4531
              Originally posted by dougs87325is
              increase cc of chamber. .
              you mean, DECREASE the cc of the chamber? I bet you don't even know what cc means.
              what you're talking about sounds like a very bad idea
              1989 cirrisblau-metallic 325i
              • dougs87325is
                • 32
                spec, have you ever built a motor? Im talking about filling in areas on the combustion chamber to decrease the chamber, right. I Cant change the dang title, know how to do that? Thanks for catching that tho.
                A machinist would know what Im talking about and trying to do I guess.
                • dougs87325is
                  • 32
                  Im a NOOBIE
                  • jasonsnoddy
                    • 1900
                    Im a NOOBIE
                    i noticed you are from mexico, is your e30 a truck
                    Originally posted by stewie30luvr
                    ooo cause i was fixing my chain tensioner and there was a black widow on the radiator so i killed it
                    Originally posted by JakeP
                    with a coathanger
                    • george graves
                      • 19996
                      Good thread. Great thread.
                      Originally posted by Matt-B
                      • dougs87325is
                        • 32
                        Jason that's not even right.It's supposed to be New Mexico. The other thing I don't know what your talkin bout. I was seriously close to turning the Eta into a pick-up, amazing, your a mind reader. Props
                        • jasonsnoddy
                          • 1900
                          my humble apologies, good sir.
                          with a coathanger
                          • E30Nova
                            • 1546
                            This thread reminds me of that build thread in Mexico where the guy had an Evo (or some Mitsubishi I think) and the "builder" drilled holes in the pistons and carved patterns into the combustion chambers for extra horsepower. :rofl: :rofl:
                            Matt
                            Matt
                            I pack my CD player with asbestos. Those mother fuckers pay dearly for stealing my shit.
                            Originally posted by kronus
                            try whacking parts of the motor with a wrench while yelling "YOU WANT SUMMA DIS? HUH?"
                            This is like a reverse build thread; it starts out nice and gets shitty.
                            • Adrian_Visser
                              • Jun 2006
                              • 2823
                              Matt
                              Lol I recall watching some news segment on tv about some dude in India of all places who carved designs in the combustion chambers of rickshaw engines and swore it made them run better.
                              OP welding and grinding your combustion chamber isn't a good idea.
                              '89 Alpine S52 with goodies
