RX7 calipers installed, experiencing something strange !
  • chris_rai
    • Sep 2009
    • 99
    i'm using
    -Fc calipers
    -hawk hps pads
    -VW rotors with inlet diameter bored to 66mm
    -15mm H&R wheels spacers
    -15" BBS wheels
    all has been perfectly installed and checked 30 times
    the problem is bad sound comming from the wheels area, when i put a strong press on the pedal, with hard braking.
    looks like something is grinding while the wheels are spining to stop the car on HARD braking, maybe pads to rotors, but there is no real feedback neither on the steering wheel or the brake pedal.
    there is a lot of space between calipers and wheels. Wheels spacers are chamfered to pass the 66mm hub diameter ( since the VW rotor is thinner ).
    help
  • b*saint
    • 3794
    you put rx7 calipers on a vw then posted for help on a bmw board? i don't get it. best thing to do is have someone drive it and you stand outside of the car and listen.
    Ma che cazzo state dicendo? :|
    • chris_rai
      • Sep 2009
      • 99
      no it's on E30 !! ( vw rotors + rx7 calipers, ghetto big brake kit ! )
      • Wishno87
        • 6025
        Backing plate?
        • Massive Lee
          • Sep 2006
          • 6785
          Pictures? ;-)
          Could well be the simple noise of the friction between pads and rotors. Some pads will emit a grinding noise. Unless you have fitted your pads in reverse...
          Lee
          massivebrakes.com
          • Wishno87
            • 6025
            Ya my brake pads emit a noticeable amount of noise as well.
            • chris_rai
              • Sep 2009
              • 99
              they can be fitted in reverse ? you mean rotating direction ?
              • Massive Lee
                • Sep 2006
                • 6785
                Nop. I meant pads flipped, and backing plate rubbing on disc. Don't laugh. I've seen it.
                massivebrakes.com
                • chris_rai
                  • Sep 2009
                  • 99
                  strange, no feeling in the brake pedal. Maybe something in the steering, but not really noticable ( manual rack steering)
                  i'v tried to grind the calipers where there is the less space with the wheels, with no succes. The noise is always here.
                  I'v seen there is a lubricant, in the pads box " to silence braking noise " applying it on the rear of the pads.
                  i'll try tomorow
                  • chris_rai
                    • Sep 2009
                    • 99
                    Sound is a thumping noise, pulsating noise !
                    • McGyver
                      • 4604
                      (...ghetto big brake kit ! )
                      • payney8
                        • Jun 2007
                        • 899
                        lol mcgyver ;)
                        • chris_rai
                          • Sep 2009
                          • 99
                          Problem solved !!
                          it needed some oil on the wheels bolts ( conical surface ), to finnaly get a true 100Nm torquing.
