Car Not Starting... All the time
  • Will_318i
    • Jan 2010
    • 482
    So here is the deal, my car isn't starting all the time like it was before. It started on Sunday when I was getting off of the freeway and hit a bump in the road and the car just shut off. I was still rolling trying to get the car started, and after a few key turns it did. And it started fine after that.
    Then yesterday, I was heading to my apt. Someone was backing out and I went to flash my high beams at them to give them the go ahead. The car just shut off. Took a few key turns to get it started again. Then when I was going to leave, the car wouldn't start. Took about 5 min for it to start. Then when I went to turn my headlights on, dead again.
    So finally today, when i was leaving my house for work, it didnt start until 2-3 key turns. Then while getting gas at costco, it wouldn't start at all. Took like 15-20 key turns for it to finally start. So I'm not sure where the problem lies, and I need some help cause this is my DD and I do need it for work.
    Thanks for the info.
    "get in, get off, wipe your dick off on her sheets and get out."
  • Kershaw
    • 11822
    flashing the high beams sounds like an alternator problem.
    AWD > RWD
    • Will_318i
      • Jan 2010
      • 482
      fuck, someone else said the same thing. i just wanted to confirm...
      • McGyver
        • 4630
        radio cuts out too and windows really slow? you probably have a bad alternator. but the good news is you can get a new one from auto zone for $80 with a lifetime warranty so when it stops working again in a year your covered! you only lose about 20 minutes of your time swapping it out in the parking lot.
        • Will_318i
          • Jan 2010
          • 482
          ok, so that's not whats happening. When the car turns back on, everything works fine. All the accessories work until the car dies, then nothing works. But i looked up the price for the alternator, it's like $140. fucking cocks...
          • McGyver
            • 4630
            yeah, advance auto is around 80 for a shitty one that will break in a year. BUT the warranty is lifetime so your covered.
            • for3ver
              • Apr 2007
              • 329
              It could be the battery cables make sure the connections are clean and tightened down properly.
              • Will_318i
                • Jan 2010
                • 482
                one of the connections to the battery was jacked up. figured this out yesterday after work when i moved the connection and it broke. but now the car cranks and doesn't start. and when i put the jumper cables, it starts right up. i think it's either the battery now or the alternator... gonna check it during lunch.
