What in the fucking cock?!
  • Uber E30
    • 1409
    If you have a 318 then you can hit the nut from the front of the car with a 3/8 wrench and a 22mm socket. On a 325 i use a long 22mm ratcheting box wrench, have the bend face downward, disconnect the loli from the body, remove the small heatshield too and you can get enough room that way.
    -Alex
    • McGyver
      • 4634
      ^that sounds like alot more work than it should be on the 325. just get a ratcheting wrench and it is ridiculously simple.
      • TwoJ's
        • Oct 2005
        • 4908
        That inner ball joint was a bitch for me too. I think I unbolted the engine mounts and lifted it with a jack, but I'm not sure about that. Sounds like the O2 socket would be better.
        • gearheadE30
          • Jun 2007
          • 3734
          haha I love the eloquence in the first few posts. :)
          Project M42 Turbo
          • Adrian_Visser
            • Jun 2006
            • 2823
            Just drop the subframe. With a jack under the oil pan of course. It's 4 bolts and then you can get in there easy.
            '89 Alpine S52 with goodies
            • Wh33lhop
              • 11705
              Try removing the engine, getting those LCA bolts and installing an M50. Worked for me.
              paint sucks
              • AbsorbantNut
                Non faccio funzionare questa merda
                • Jun 2010
                • 2491
                I thought he got it out. Wtf up with the posts on telling him how to do it after the fact?
                '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
