In need of 91 318is C101 Pinout
  • ZekeTheSneak
    • 1562
    I found the 89 pinout i needed, but just looking to fill in some blanks on my 91 side,
    C101 for 318is so far
    pin 1 blue alt charge warning
    pin 2 empty
    pin 3 empty
    pin 4 br/vi temp sensor
    pin 5 bk/br oil pressure
    pin 6 gr/yl unknown
    pin 7 gn ignition
    pin 8 yl/wt unknown
    pin 9 bk tach
    pin 10 empty
    pin 11 wt/bl unknown ignition?
    pin 12 br/bk unknown ignition?
    pin 13 vi/rd fuel pump
    pin 14 bk/yl oil level sensor ?
    pin 15 bk/gr starter small connector
    pin 16 wt/bk unknown srs computer
    pin 17 empty
    pin 18 bk/yl starter large connector
    pin 19 empty
    pin 20 yl/rd abs brakes ???
    this is all from misc searching, thanks
  • nmlss2006
    • 910
    Did you also look http://shark.armchair.mb.ca/~dave/BMW/e30/e30_91.pdf here? That document is the diff for 318s, basically.
    • ZekeTheSneak
      • 1562
      a little but its all confusing, why isnt there just a definitive pinout chart like how hard could that be?
      • Jean
        • 18228
        Because there are various of changes between years/models? How hard can it be, spend 30 minutes with the ETM and you'll know for sure.
        • nmlss2006
          • 910
          What he said. The pinout is a bitch, yes, because you have to go all over the 318 ETM which I linked to AND the 89 325 ETM to make sure you get all the pins. I have the pinout for a late model 6 cyl but I am purposefully not posting it to avoid potential disasters, as several sources confirm that the 318iS is different.
          • E30SPDFRK
            • 5716
            I posted it in the m30 section before, look around there.
            Byron
            Leichtbau
            • ChaseN
              • 709
              Yeah, you might as well go through the ETM for you car. If you can get a hold of a searchable PDF, just hit CTRL+F and type in C101, then write down every hit you get, and see what you come up with.
              If you don't have a searchable PDF though, it still isn't that hard.
              1991 318iS
              1992 911
              2006 330i 6-Spd ZSP people hauler
              Gone:
              1989 M3 S50B32, 6-Spd
              1990 325ix 5-Spd
              • ZekeTheSneak
                • 1562
                thanks, i made a spreadsheet with a bunch that i have found to compare my findings, i will go through the etm tonight
                • Garageaholic
                  Freestyle Fabricator
                  • Dec 2005
                  • 5204
                  Yeah, The ETM will help very much. The schematics really work wonders. Just go through EACH page and look for a C101 connection!
                  Recent Rebranding!!
                  E30 SM62/S62
                  E30 M60 V8
                  E30 M30 Big 6!
                  Instagram.com/garageaholic
                  Youtube.com/garageaholic
                  • ZekeTheSneak
                    • 1562
                    fml, lol. hopefuly running tonight
                    • ZekeTheSneak
                      • 1562
                      oh these schematics are ok, i take it 88 and 90 are major years.
                      • ZekeTheSneak
                        • 1562
                        I believe i found my problem, between the two years the 91 ignition is controlled by different relays and my car still wont start. any insight?
                          • 34844
                          bump - anyone have a *complete* '91 318is ETM? the one floating around (~5.9mb) is missing about 2/3rds of the sections. Which is funny when you guys tell somebody to search the ETM. ;)
                          I know there's a 16mb version but I haven't found it yet..
                          • nmlss2006
                            • 910
                            Nando, as far as I know the 91 318iS etm that is 'small' is the diff from the 89 325 one. So you get to have two PDFs open.. ask me how I know :).
