i too have heard of these cat things. no emissions for me so the trunk monkeys took mine away.
Aviation gas
100LL will destroy your o2 sensor and kill your cat. The 100 is the octane and as said above, not really the same scale as we get at the automotive pump. Shell 94 would be better for most of us. The LL stands for Low Lead. However there is nothing low about it's lead content. After it kills your o2 sensor and cat it will lead foul your plugs and may leave lead deposits on your valve seats.
I have run it in my 2002 years ago but the hassle of the fouled plugs and different air idle mixture required made it a pain in the ass. It also ate and loosened the plastic gunk sealer in my gas tank. I pulled most of it out through the sending unit as it came out like big pieces of fruit roll up.
100LL is for airplanes and maybe the occasional Coravair.
JohnThe Revolution will not be televised.Comment
Instead throw some nitromethane in your tank. ( I am not going to be held responsible for you doing this though.)Originally posted by devon.818low key i actually paid attention to the drifting...then saw bouncing tits and went :oOriginally posted by devon.818as for a 4hr boner...idk, start using it for things; cup holder, dial the phone, type with it, fix things, diagnose the e30, probe random shit...Originally posted by Mercury[BKM]...because Machine GunComment
If you get caught buying 100LL (or other aviation grade fuel) and using it in your car, there are hefty fines to pay. IIRC it is ok for offroad use in ATV's and bikes, but I could be mistaken there. Just something else to think about, though not sure how someone would actually get caught unless they were actually dumb enough to pump it straight into their car at the airport.e92 M3
e30 M3 s52 swap
w203 C240 wagon (DD)
190e 5.6 swap (in surgery)Comment
would a jet engine work in ma 318i auto gyz>?>>>>??Originally posted by e30elose the old man bmwcca badge.Comment
trans not required!
Actually JP-5/8 is used regularly in military diesel trucks with no problem, presumably Jet A could be used too. Only real difference is that our fuels have anti-ice, anti-fungus additives. Probably wouldn't want to try Jet-B though unless I were in Iceland or something....e92 M3
e30 M3 s52 swap
I don't know, they have gotten a lot freeer flowing than they used to be and, damn would you look at that, You can breath in LA.
e92 M3
e30 M3 s52 swap
At the local airport the night before drag races all the hillbillys would load their cars up with av-gas and go to the track. Granted they were all pretty much Chevy 350 so it really didn't matter if you blew it up or not. I know some of them would run the extra on the street on non-race nights though.1974.5 Jensen Healey : 2003 330i/5Comment
