Massive vibration and clunking.
  • DanMan68
    • 204
    So on the way to work this morning, my car was fine. On the way home it started clunking and vibrating. It gets worse at speed, but the weird thing is that under acceleration it is mostly fine, constant speed it is noticeable but not too bad, but with no throttle it is really bad to the point of being scary, and the under braking not so bad. It is defiantly drivetrain related, as you can hear distinct clunks until you get going faster.
    So my guess is driveshaft failure, but I haven't been under the car yet.
    Any other ideas?
    So where can I get a good remanufactured driveshaft? Pelican has them for $800, Bimmerworld $450 but you have to give them your core. looks like they rebuild it with replaceable u-joints though which is a plus. There and this other site I found http://www.wholesaleimportparts.com/...shaft_1989.php But it looks a little questionable.
    Any other suggestions? I know there was a guy on here that was saying he could rebuild them for like $300 bucks, but I couldn't find the thread.
  • Nic01101011
    • Jan 2008
    • 1549
    Could be the guibo..
    Look under the car and see if it's shredded and hanging down..
    • Dude
      • 1119
      Sounds exactly like when my guibo broke. I still havent fixed it but it got a little better over time for some reason haha. But if you can get your car up on a lift or get under it and look between the driveshaft and the tranny its that rubber giant washer type thing. I doubt its just your drive shaft. Could also be your center support bearing,
      • kronus
        • Apr 2008
        • 13031
        It is either: the Center Support Bearing (CSB) or the guibo.
        It is not: the diff mount bushing, the trans/engine mounts, or your driveshaft (unless you continue driving it like this)
        cars beep boop
        • stumble_t
          • Aug 2009
          • 759
          I just put one in from HERE.
          Great product. I think it was $500 shipped with a $75 core return inc. shipping both ways from Portland.
          [IMG]http://www.r3vlimited.com/board/
          • DanMan68
            • 204
            There has been a slight clunk (a single clunk on acceleration and deceleration) for as long as I have owned the car (1year), so I replaced the gubio as well as the CSB about 5 months ago. It didn't fix the problem, so I am thinking it was the driveshaft all along and it is just now becoming a serious problem.
            • stumble_t
              • Aug 2009
              • 759
              If the csb or guibo are bad and keep going bad the d-shaft is shot.
              The off load clunking could be due to the large retainer nut on the spline being loose or off.
              • bmw325csi
                • May 2007
                • 4045
                my guibo and csb kept going out, same symptoms, mainly going uphill. I had to replace my driveshaft to remedy it.
                harry/harout
                • DanMan68
                  • 204
                  Well I just figured out what it was, do you think you can guess? It has nothing to do with the driveshaft and I already fixed it.;)
                  It does have to do with me being a total tard though.:stupid:
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    Lugs loose.
                    john@m20guru.com
                    Links:
                    • DanMan68
                      • 204
                      yup. I should have thought of that to begin with, but thankfully it didn't mess up the rim or hub.
                      • JT325is
                        • Oct 2009
                        • 1242
                        CSB nuts are loose or it may be cracked and old
                        • bmw325csi
                          • May 2007
                          • 4045
                          lolz, it happens, thanks god you didnt lose a rim driving
                          harry/harout
                          • DanMan68
                            • 204
                            I know right! And at least I dont have to spend 500 on a driveshaft either.
