Shake after 50mph
  • ZekeTheSneak
    • 1562
    Shake after 50mph
    My steering wheel shakes after about 50mph, this just started after my rack and motor swap. I believe the cause is loose tie rods. I was wondering can the shake be coming from the rack? It has a 96 m3 rack with unknown miles.
    Ill will be digging into it this afternoon and hopefully its just something loose not a destroyed rack.
    Thanks
  • nomansland92
    • 1657
    well if it didn't shape before then that pretty much rules out a lot of factor like bent rims and out of balance tires or bad wheel bearing( i've had them all ugh) so the first places i would check would be tire rods and see if there is any play in the rack be jerking the tire back and forth and have someone watching for moving and non movie parts
    hope this helps
    IX being restored here
    Ix turbo build here
    • ZekeTheSneak
      • 1562
      Well turned out my motor mount was loose, Thats all tight and will never be loose again. Haven't driven it yet due to finding a coolant leak :(.. I was looking at the flex disc in the steering linkage it sort of wabbles. Could this be an issue? I saw a website where you can get a Poly one which i will be ordering shortly
      • dude8383
        • Jan 2005
        • 10387
        Are you referring to the flex disc aka the guibo?
        • ZekeTheSneak
          • 1562
          Yes i am, After looking at it awhile (AIRBAG CAR) i decided im going to cut it out and make it solid, See what happens. Bad idea?/
          • ak-
            • 12422
            All my experience in 50mph - 65 steering shakes have been caused by:
            Bad tie rod
            Bad balljoint/CA
            No hubcentric rings
            Bad alignment/no alignement after messing with suspension.
            Just thought I'd add that.
            1991 325iS turbo
            • dude8383
              • Jan 2005
              • 10387
              BAD IDEA. There needs to be some flex there. There was a thread on this sometime ago...try searching for it.
              • avery0829
                • Dec 2008
                • 793
                well is there supposed to be some free play in the rack at the top? My guibo seems to be fine but there is play between the linkage and the top of the rack. I have some hockey pucks that may be turned into a new guibo :) never hurts to try
                -ZekeTheSneak
                • HarryPotter
                  • Jan 2010
                  • 3642
                  Are you talking about the steering rack or the driveshaft? I'm gunna say the rack, I'm pretty sure you can make that bushing solid.
                  John F. Kennedy
                  • ZekeTheSneak
                    • 1562
                    Steering rack, people what have i been talking about? haha
                    • Super Sedan
                      • Feb 2006
                      • 551
                      A "guibo" is slang for a driveshaft flex disc
                      • Adrian_Visser
                        • Jun 2006
                        • 2823
                        Not slang proper terminology.
                        '89 Alpine S52 with goodies
                        • dude8383
                          • Jan 2005
                          • 10387
                          Point is that shouldn't be solid.
                          • HarryPotter
                            • Jan 2010
                            • 3642
                            This is why people thought you were talking about the guibo...
                            John F. Kennedy
                            • ZekeTheSneak
                              • 1562
                              then what is the rubber Guibo Thing in the steering linkage? I have heard it called a guibo most of the time. Still shake at 55.
