Piston rings
  • JoosyJoos
    • Jan 2010
    • 11
    Piston rings
    How much would it cost (approximately) to have piston rings replaced at a local shop? Just take a crack at it I need a rough answer lol
    Thanks.
  • Vtec?lol
    • Dec 2009
    • 3278
    $600+
    • Cabriolet
      • 9620
      do it your self it is really easy.. semi easy.... just rebuild the whole engine if you are going to do it.
      Much wow
      I hate 4 doors
      • Pac1373
        • 1746
        I would agree with this.
        Originally Posted by ACMF74
        i clicked on this cuz i saw p3nis
        • ttrousdell
          • Nov 2009
          • 1770
          mad coin. gots to pull the head and open up the oil pan. yea by that point just replace the bearings and all that other stuff (gaskets). if the piston rings are fucked the bearings have prob seen better days
          The Build:
          • ttrousdell
            • Nov 2009
            • 1770
            how many miles are on it. guess your getting lots of blow by. did u do a compression test before u take such drastic measures
            The Build:
            • call me jack
              • Jul 2010
              • 425
              you really only need to remove the oil pan if your just replacing rings... but if your going to rebuild the engine, obviously your going to have to take the head off, during tear down.
              on that note, i suppose it could be possible to have your cylinders bored, even, with the head still one... though i would call you shop and ask first. Otherswise, as stated before, if your going to have you ring replaced, just have the whole engine rebuilt.
              • TS323
                • 359
                Originally posted by cabriolet
                do it your self it is really easy.. Semi easy.... Just rebuild the whole engine if you are going to do it.
                +1
                • JasonC
                  Site Manager
                  • 14451
                  These's something called a crank thats in the way if you was gonna remove the pistons from the bottom.
                  1992 BMW 325iC
                  1978 Chevrolet Monte Carlo
                  • call me jack
                    • Jul 2010
                    • 425
                    i ment as appose to removing the head...
                    • JasonC
                      Site Manager
                      • 14451
                      Do you know what you're talking about??? Cause you got me totally lost...
                      1992 BMW 325iC
                      • Dj Buttchug
                        • Jun 2010
                        • 7681
                        ummm no. crank in the way on the bottom. heads in the way up top.
                        rings require a full teardown...
                        Turbo M42 Build Thread :Here
                        Ig:ryno_pzk
                        I like the tuna here.
                        Originally posted by lambo
                        • slammin.e28
                          שמע ישראל
                          • 12054
                          x9999999999999999999999
                          The hardest part would be getting the Jesus nut off the front of the crank, just get really good air gun and rip it off while you still have the motor together. Then it's all easy stuff from then on. Get a whole rebuild kit, bottom end gaskets, bearings, seals, piston rings, top end gaskets, seals, etc.
                          My boy just got his block honed and cleaned, pistons graphite coated, etc for like $150 at a local machine shop. In total, including the cost of the engine, and all the gaskets, seals, rings, bearings, etc, he's got probably $500 wrapped up in it, maybe less.
                          These things are like freakin' Legos. DIY and save some coin, and learn something while you're at it!
                          • call me jack
                            • Jul 2010
                            • 425
                            really? i'm pretty sure i replaced the rings in my gm 3800 a couple years ago. just took the oil pan off, detached the connecting rods lowered the pistons down, to replace the rings... now did it work? yeah... for a little while. would it have been more worth it to just rebuild the engine. fuck yeah. but i was just trying to clarify a situation for the OPs benefit.
                            Don't mean to step on any toes, but now i feel i need to be extra clear....
                            ...Unless of coarse this engine isn't as accessible, as i have not tried this on my M20, or even taken the oil pan off for that matter.
                            Edit: i was 16, when i did that procedure to the buick... It sounded like a good idea at the time.
                            double edit: to be super duper clear. OP just rebuild it.
                            • Dj Buttchug
                              • Jun 2010
                              • 7681
                              yea pretty sure it cant be done that way with an m20. there is no room.
                              Ig:ryno_pzk
