Engine oil in Air Filter Box?
  • Cyrano
    • 163
    I opened my air filter box couple of weeks ago to find engine oil on the air filter.. I took out the filter, cleaned the box, drove for a week opened it up again and oil is there again.. What could be the culprits to this. Is it just a sign of an old engine... worn pistons? What could be done to seal it... Im still running the car without an air filter...
  • 325ix
    • Aug 2009
    • 7783
    Are you sure it is engine oil and not oil from an oiled air filter? Also the crank case vent on top of the valve cover does spit some oil into the intake tube.
    • Cyrano
      • 163
      Yes, its the engine oil 100%. Do the E30's have a PCV valve?
      • McGyver
        • 4637
        i get a SMALL amount of oil in the filter end of my AMF on both my cars. im guessing its normal.
        • 4bangerfury
          • Aug 2009
          • 335
          A little bit in the intake is normal because of the crank case vent.
          • mrsleeve
            • Mar 2005
            • 16387
            no there is a Crank Case Vent into the bottom of the intake just after the Throttle body. And its normal
            Originally posted by Fusion
            William Pitt-
            • vivalegreg
              • Apr 2006
              • 1313
              running the car without an air filter? what are you thinking?
              e30s r kool
              • Cyrano
                • 163
                Can the crankcase vent get clogged allowing less oil to be vented out?
                • delatlanta1281
                  Dart Master
                  • Mar 2006
                  • 10317
                  ORLY?
                  You sure he didn't just omit the part about putting the filter back in the box? I bet he did.
                  Yours truly,
                  Rich
                  you kids get off my lawn.....
                  • Cyrano
                    • 163
                    I took the filter out intitialy because when i first checked it it was soaked. I wanted to see if the oil had just accumulated over time on the filter, so I ran it for a week without filter, opened the box and I found a good amount of oil. At this point im asking on what I can do to reduce the amount of oil being spit into the box, because i cant be changing air filters monthly.
                    Im guessing its worn piston rings or clogged valve... hoping the latter is possible and that that is the actual cause.
                    Any more input will be appreciated. thanks all
                    • delatlanta1281
                      Dart Master
                      • Mar 2006
                      • 10317
                      I
                      Stand
                      Corrected.
                      Dont drive your car without a filter man, if you think plowback is bad, wait until you suck something into your valves.
                      Sorry Greg.
                      Yours truly,
                      Rich
                      • Dj Buttchug
                        • Jun 2010
                        • 7686
                        guess what homies. you have blow by...
                        Turbo M42 Build Thread :Here
                        Ig:ryno_pzk
                        I like the tuna here.
                        Originally posted by lambo
                        • HarryPotter
                          • Jan 2010
                          • 3642
                          Shot
                          John F. Kennedy
                          • Cyrano
                            • 163
                            Shot
                            NO IM NOT:tsk:
