Windshield wipers will not turn off
  • ZekeTheSneak
    • 1562
    Once clicked to any position my wipers will not turn off, I have replaced the relay (in engine bay big black one), and the wiper stock.
    What is next? the motor?
  • Cabriolet
    • 9620
    you need to replace the switch in the steering column, sounds like it is not dropping connection once it is switched to the off position.
    Much wow
    I hate 4 doors
    • ZekeTheSneak
      • 1562
      I replaced the stalk.... meaning the switch
      • worangejuice
        • 1837
        Mine dud this in the rain last night, but eventually went off after messin with it
        www.woranges.tumblr.com
        • RainierHooker
          • Jul 2009
          • 2026
          You may want to try the wiper control relay. Its the big black one in the fusebox. you could have a broken/stuck pole. They are expensive new, but you should be able to find one at a junkyard for cheap, most folks don't know what they are...
          Edit: nevermind, I just saw that you already did that...
          I guess all you can do is re-check the contacts in the fuse box and make sure that the harness in the steering column is in good order. You might have a bad ground or a chaffed wire somewhere along the bundle.
          1984 Hennarot 325e - 1990 Brillantrot M3 - 1938 Buick Special Business Coupe
          • McGyver
            • 4510
            mine do that from time to time because a wire's jacket melted so the metal grounded on the car. so you could check to see if you have any exposed metal around the wires.
            • stumble_t
              • Aug 2009
              • 759
              this happened to me and I found a spare fuse stuck under the relay in the fusebox.
              [IMG]http://www.r3vlimited.com/board/
              • ZekeTheSneak
                • 1562
                Thanks I will trace the wiring,
                • YetiX
                  • Jun 2010
                  • 136
                  How awesome is this thread? I posted something on M42Club yesterday because I've been having this same problem. Got the same answers as here except this one. So I go look at my fusebox and what did I find? A fucking spare fuse stuck under the damn relay!! :D
                  Scott '91 318i/5 spd
                  • e30:)
                    • 728
                    this can also make the wiper washer spray untill it runs out ha i know from experience. both have happend to me
                    • LowR3V'in
                      • 4209
                      Do they turn off when a/c is on?
