need some engine build advice
  • Philo
    Ich esse kleine Kinder
    • 3334
    Well don't yank the engine just yet. I'd make sure everything is properly torqued to begin with. Make sure it's not leaking down from somewhere else.
    -tim
    Originally posted by Jordan
    I like the stance
    • Dj Buttchug
      • Jun 2010
      • 7688
      true true. I torqued everything to spec so i cant see where i went wrong there.
      Does anyone have any experience with this stuff? I have never used it because I was always told to shy away from it. Now that Im dealing with leaks ON A BRAND NEW ENGINE!!! maybe I should have considered coating my timing case and oil pan gaskets before installing??
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • Danny
        • 14216
        I used that on my turbo's gaskets.
        • whodwho
          • Jun 2008
          • 1547
          Did you use new flywheel bolts or seal the ones you used?
          My M20 Frankenbuild(s)
          4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
          • blueapplesoda
            • Dec 2005
            • 1904
            ^This
            you'll need some kind of thread sealant on those buggers
            What about the gasket on the rear main seal housing? and it could also be your oil pan gasket... check the head for any leaking, hopefully its not dripping down from the top?
            maybe the rear main seal was slightly cockeyed in the hole when you were pressin it in?
            edit...i gave up trying to seal an old/refreshed/rebuilt engine with new gaskets. I've had shitty luck with all the product on the market. Using gasket caulk works wonders when used right. especially in turbo engines, cause they essentially "glue" things together.
            • Dj Buttchug
              • Jun 2010
              • 7688
              welp thanks for the help guys... victor reinz can SUCK MY BALLZ
              I will spend this weekend re sealing my whole motor with permatex Rtv gasket maker.
              let this be a lesson to those rebuilding or refreshing engines.
              Ig:ryno_pzk
              • Stephen
                Шлем ишака
                • 10774
                Timely info, good to know about the VR gaskets.
