what does the pulse sensor do on an eta?
  • call me jack
    • Jul 2010
    • 425
    as the title suggests, was wondering what the pulse sensor does on my eta.
    I don't understand why it exists when there are already 2 speed sensors on the bell houseing.
    if you didn't know, i'm referring to sensor on the fly wheel hub at the front of the engine.
  • LTDScott
    • Jan 2008
    • 259
    I believe this is strictly for diagnosis only and has no bearing on the engine actually running. The two sensors on the bellhousing are what gives the computer info for engine speed and timing.
    The Homer: Powerful like a gorilla, yet soft and yielding like a Nerf ball.
    • call me jack
      • Jul 2010
      • 425
      but etas use motronic 1.0, which doesn't have any diagnostic capabilities.
      • hotballs
        • 1155
        By "flywheel hub" at the "front" of the engine, do you mean crank pulley? I don't remember a sensor being there on my eta.
        Or do you mean the pulse sensor on the plug wires. Also eta doesn't have that.
        • call me jack
          • Jul 2010
          • 425
          i'm referring to the sensor on the front of the engine, that reads the crank pulley.
          • LTDScott
            • Jan 2008
            • 259
            I shouldn't talk out of my ass so much, but when the tab on the flywheel of my car broke and I was pulling my hair out trying to diagnose the problem, I remember the Bentley manual stating that the front sensor was for diagnosis only. Exactly what that means, I don't know.
            • delatlanta1281
              Dart Master
              • Mar 2006
              • 10317
              Unplug it and see what happens ;)
              I bet your car won't run right.
              Yours truly,
              Rich
              you kids get off my lawn.....
                • 34844
                I know it will run right because it doesn't go to the ecu at all. It goes to the diagnostics port.
                • delatlanta1281
                  Dart Master
                  • Mar 2006
                  • 10317
                  Shhhhhh.
                  Don't listen to Nando. Do it.
                  Yours truly,
                  Rich
                  • call me jack
                    • Jul 2010
                    • 425
                    i did it a couple of days ago. it's what inspired the question. car runs fine. it's still not reattached.
                    • LTDScott
                      • Jan 2008
                      • 259
                      Yup, that confirms what I thought. I guess the dealer could plug in a diagnostics computer into the service port and the front sensor is used for engine timing diagnostics.
