Economist Article: "The Difference Engine: All change, oil change"
  • Kovs
    • Oct 2006
    • 483
    Popcorn ready.
    Mike
    82 Alfa Spider (For Sale)
    86 944 Turbo
    87 CX25 TRD Turbo2
    89 405 Mi16
    89 Milano Verde
    89 Mondial t Coupe
    92 300D
  • McGyver
    • 4637
    thats interesting. my friend's dad told me that he uses rotella in all their cars, and now i guess i know why.
    • FredK
      • 14762
      Plunging ZDDP levels causing accelerated wear on engines has been a known problem for quite a while.
      Mobil1 15W-50 is a good choice in most older BMW engines.
        • 34844
        just use M1 15w50 and forget about it. ;)
        It actually has more ZDDP in it than those diesel oils, and it's not formulated for an entirely different kind of engine..
        • tjts1
          • May 2007
          • 1851
          Survey says NO.
          Its the same 1200-1300 ppm.
          EDIT: And since when did the economist start to care about ZDDP? Nice find.
          • Hick
            • Sep 2005
            • 6451
            FWIW, I used Amsoil HDD (Heavy-Duty Diesel) in my m20 and m42
            Phosphorus 1266 ppm
            Zinc 1379 ppm
            Just about the same ppm for the entire Amsoil line
            Originally posted by vlad
            • NigelStu
              • 827
              Amsoil 'premium protection' 10w40 and 20w50 and AME 15w40 diesel oil are about the same as the HDD for Zn/Ph levels too.
              Anyone running sans cat (like on a track car), any of the 'not for street use' racing oils would be good also. Amsoil Dominator, Bradd Penn grade 1, Valvoline VR-1, Mobil 1, Redline, etc.
              There is a TON of info on www.bobistheoilguy.com not the easiest site to find the info, but a lot is there...
              Is this type of wear a real concern in the M20 engines? Has anyone (especially those who track their cars) seen cam wear related failure when using recent oil with less zind/phosphorus levels?? Is the facotry requirement higher ZDDP content? Amsoil site has recommendations of 'SM' grade, which is the newest grade and does not require as much ZDDP...
              Ben
              Thelma-Louise, the '88is Chump Car - back to M20 power!
              2014 ChumpCar Season Schedule!
              April 5-6 Autobahn, IL - Sat: 1st! Sun: 3rd
              May23-25 Watkins Glen, NY: 4th, 5th, 4th
              October 4 PittRace Sprints: 2nd in C-class
              October 18-19 NCM, Bowling Green KY: 2nd, 1st!
              Nov 1-2 Watkins Glen - Chumpionship - 1st car to exit the race with significant body damage :(
              Find us on FB! Schaut Speed Motorsports
              • chrisesteschiro
                • 361
                I run amsoil racing 15/50 myself. More expensive but much cheaper than a rebuild.
                • xwill112x
                  • Jan 2009
                  • 4236
                  run rotella 15-40 in the m42. it seems to like it, less ticking suprisingly.
                    • 34844
                    Originally posted by tjts1
                    Survey says NO.
                    well at least it's formulated for the proper engine. the additives packages of a diesel oil isn't anything like a gasoline version.
                    you prove your stupidity once again. The M42 doesn't have solid lifers like an M20. it doesn't care about ZDDP in the same way.
                    • xwill112x
                      • Jan 2009
                      • 4236
                      and you prove your ignorance thinking that was my point. diesel oils aren't bad for gas engines, and 90% of the time its cheaper, and better for it. they have more detergents to keep the engine cleaner, and better lurication qaulities, so why not get it? jesus. find someone else to follow around and jump to conclusions about.
                      • Bimmerman325i
                        • 6854
                        Good information in the article.
                        British editorial writing conventions are a bit different.
                        2017 Chevrolet SS, 6MT
                        95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
                        98 M3/4/5 (stock)
                        • tjts1
                          • May 2007
                          • 1851
                          Citation needed.
                          Rotella 5W40 has an API SM gasoline rating.
                            • 34844
                            so? since when did API ratings actually mean anything?
                            and are you really going to run a 5w40 oil in an M20? do you live in northern alberta? :p
                              • 34844
                              "more detergents"
                              but what KIND of detergents? Also, more detergents means less base stock. Just like dino oils with huge temperature ranges have more viscosity modifiers and less base stock.
                              and yes, you are a moron. :p
