Heater not working and its cold out here...
  • McGyver
    • 4589
    or it could be so cold out that the heater isnt able to warm the air as you drive that fast. did you push the recirc button?
    • tjmonsen5
      • Jan 2006
      • 232
      Originally posted by Killacortes
      engine temp stays right in the middle.
      the hoses are not backwards
      its hot at low speed and cold at high speed
      i can be at 5k in 1st and feel the heat but at 2.5k going like 40 or something it gets cold again
      That sounds like your heater core is clogged up with crap. Mine is pretty much the same way. It gets warm, but nowhere near as hot as my other E30. If only heater cores werent so expensive!!
      • evil_twin
        • Nov 2007
        • 2965
        Originally posted by Danny
        Your hoses going into the firewall are routed backwards.
        Check that. It's probably the 1st thing I would go to because it seems to happen a lot.
        Originally posted by e30trooper
        hmm. its sorta hot when first turned on then cold since. Your not fuckin with me danny are you? If your right i will buy you a paid of boxers with ur name on it :)
        Multiple threads on it. I swapped mine too :)
        OP, is the blower blowing air? and just cold air is coming out? Or is the blower not changing speeds?
        Paypal: vdang5@gmail.com
        Delta Auto Care
        2875-C Towerview Road
        Herndon, VA
        703.435.1375
        My Feedback Thread: Evil_Twin
        • 87e30
          • Jul 2008
          • 5676
          I said exactly what danny said first. He's right.
          I just hate everyone.
          No need for discretion.
          • Killacortes
            • 1937
            the blower is blowing air and changes speeds. just cold air comes out when im going high speed..
            lately its seems to not turn on all the time
            hoses are good
            r3v does not fuck around. First you get banned, then they shoot you
            • 87e30
              • Jul 2008
              • 5676
              hoses are good
              Are you sure that they are in the proper orientation.
              There is one coming off the head and one coming from the spider hose area (honestly don't remember right now) And you have to make sure the right one is in the top of the firewall heater core pipe and the right one is in the bottom. Dont' remember which goes where at the moment.
              • Killacortes
                • 1937
                Yes hoses are good.
                i still cant figure out why my blower only turns on sometimes. is that just a bad blower motor or should i check something else?
                • Jean
                  • 18228
                  2 pages of this and you still haven't checked the blower fan fuse, blower resistor and blower fan?
                  • evil_twin
                    • Nov 2007
                    • 2965
                    20 year old blower and resistor... that COULD be a problem.
                    Delta Auto Care
                    Herndon, VA
                    703.435.1375
                    • Killacortes
                      • 1937
                      the only fuse i found related to the heater was #20 its a 30 amp fuse and its good
                      i havent checked the blower resistor because the blower still turns on sometimes. would the blower resistor cause the blower to turn on intermitently?
                      • Killacortes
                        • 1937
                        replaced the blower motor and seems to be blowing hot air again at high speed!
                        • ck_taft325is
                          • Sep 2007
                          • 6880
                          Baaaa-booom.
                          Car's lookin' good man.
                          Need a part? PM me.
