DIY Heaterbox
  • Dude
    • 1119
    #61
    Originally posted by nando
    pretty sure those fans don't need 30 amps. lol. maybe 3 amps.
    They actually need less then .5 amps.
    I know it doesnt seem like the RIGHT way to go about heating a car. But for anyone else who wants to talk shit please give me a reason why.
    • BDSax
      Junkyard King
      • Mar 2006
      • 3593
      #62
      how about cause its fucking ghetto as fuck.
      NEED SOME VINYL STICKERS???
      • Stanley Rockefeller
        • 445
        #63
        Originally posted by Hick
        It may be easier to just have long wire leads, assuming you are going to use the 30amp power from the cig lighter, and just make it so that you can move the heater box from place to place.... Need heat on your feet, put it on under your legs. Heat for your face you could set it above the cluster on the dash. Defrost, just turn it around!
        let me know what you think!
        Too complicated! I say why not have several fans placed thru the interior (one to the dash, one to the footwell, and one for the dash vents).
        clearly, this is the best idea out there.
        Kudos to the OP for being so smrt to thinking outside the (heater) box ;)
        • The Volta
          • 321
          #64
          Just use one of these, it would be pretty ballin. I require more pics of your set up though, are those computer fans? I say let him do what he want's, it is his car. I do agree though that it is going to be harder the way you are doing it, but whatev.
          My Build
          • 10Toes
            Me Father Was A Tree
            • Jan 2008
            • 61222
            #65
              • 34827
              #66
              that right there should tell you why this won't work.
              those fans might put out 25cfm after they go through the heater core. maybe, but most likely not. the stock one is probably closer to 500cfm (or more) at full tilt.
              • Massive Lee
                • Sep 2006
                • 6785
                #67
                I have similar fans that I tried. They have very low volume, and the pressure is laughable. Basically the air will barely touch the heater core and run away scared...
                A proper fan would be the 12v marine blower. It has volume, and pushes with good pressure.
                massivebrakes.com
                • 10Toes
                  • Jan 2008
                  • 61222
                  #68
                  And for the same price you could just get a used stock heater setup.
                  • kishg
                    • Sep 2006
                    • 2624
                    #69
                    But you just left the stock unit in, my car came with NOTHING, no wiring no ducting no blower motor, no blower motor mount, no lines, no NOTHING.
                    nope. i have no heater core or hvac controls. but i don't need to drive on the street. car isn't even registered.
                    '12 F30 328i Sport Line
                    '91 SpecE30 #523
                    '00 Ford F-350 Dually Tow Vehicle
                    BMWCCA #360858 NASA #
                    128290
                    • AbsorbantNut
                      Non faccio funzionare questa merda
                      • Jun 2010
                      • 2491
                      #70
                      this thread has inspired me
                      '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
                      • Dude
                        • 1119
                        #71
                        Good reason, Its an e30 btw.
                        Yeah right now the fans are my only real concern. The way its setup the fans dont push through the heater core, they are pulling the hot air from section with the heater core and then pushing it into the vents.
                        If you HAD to heat it what would you do?
                        • kishg
                          • Sep 2006
                          • 2624
                          #72
                          stock setup or i'd use the fan lee showed to drive heat from the trans tunnel into the stock vents. take a look at this pic:
                          http://www.turnermotorsport.com/imag...3/IMG_7480.JPG
                          Your way is too complex and thus likely to fail. Try it anyways.
                          '91 SpecE30 #523
                          128290
                          • KennyT
                            • 542
                            #73
                            Buy the shit for the OEM system. All you need for wiring is a switch to turn the fan on or off, the rest is all mechanical. For a race car you don't need AC, and you don't need variable fan speeds.
                            • Dude
                              • 1119
                              #74
                              I'm liking where this is going. Have anymore examples?
                              • Hick
                                • Sep 2005
                                • 6451
                                #75
                                Dont give up now!
                                Originally posted by vlad
