318is 1991 rpm fluctuate
  • immajackuup
    • Dec 2010
    • 1132
    for some odd reason my car rpm fluctuate from 800 to 1k while idling at the red light. can a bad fuel injector cause the rpm to be bouncy ? it only does it here and there. Should I buy fuel injector cleaner for the hell of it?
  • Dj Buttchug
    • Jun 2010
    • 7688
    possibly ICV
    clean it
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • immajackuup
      • Dec 2010
      • 1132
      Originally posted by Dj Buttchug
      possibly ICV
      clean it
      do you have a picture of where the ICV locate at on m42 motor?
      • Balleristic31
        • Aug 2009
        • 4198
        Between the firewall and intake mani
        -NICK
        • immajackuup
          • Dec 2010
          • 1132
          is this it?
          so i have to take off the top manifold?
          • Balleristic31
            • Aug 2009
            • 4198
            No there is a bracket holding the icv to the corner of the intake manifold. Undo the nut and the vacuum hoses attached to it and the icv comes out
            -NICK
            • immajackuup
              • Dec 2010
              • 1132
              it be very helpful if you show picture of what you talking about.
              a guy coming from honda that rebuilt/install aftermarket parts to bmw which is totally different lol
              • ///digitalme
                • Dec 2009
                • 2088
                you dont need to untighten any nut to get it out..just disconnect the hoses...and pull it out of the rubber thing that holds it...
                • immajackuup
                  • Dec 2010
                  • 1132
                  i assume this is it
                  • iamsam
                    • Jun 2008
                    • 176
                    you assume correctly.
                    My M42 does this too, but only when it is brutally cold out. When i start my car in the morning, it's fine, and by the time the car is warmed up, the idle will bounce back and forth from 1000-1500 rpm, and it is SUPER annoying.
                    • iamsam
                      • Jun 2008
                      • 176
                      also, wrong section for this thread. There is an M42 technical section.
                      • Simon S
                        • Oct 2004
                        • 3758
                        should probably mention vacuum lines.
                        They dry out, crack, and cause leaks over time.
                        Check the simple stuff first..
                        Run some searches.
                        -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
                        • immajackuup
                          • Dec 2010
                          • 1132
                          having the same thing as you
                          sorry i'm new,just got my e30 318is for free.
                          Run some searches.
                          all the hose have been replace from the previous owner and of course i search before i ask people.
                          another question about the icv,there is a arrow on icv should it be point up toward the hood or down? also how do i clean icv because it seem the only way to clean is spraying brake cleaner inside icv hole. for honda you can take the whole iacv apart.:)
                          • kid325e
                            • Sep 2007
                            • 6422
                            Not trying to be a dick but pick this book up if you get a chance. It'll make your life a lot easier for things like this. Very nice to have just for reference. http://www.amazon.com/BMW-E30-Servic...3860468&sr=8-8
                            clutchCTRL!
                            Move with a purpose.
                            - 1991 325iX 4dr/5spd
                            - 2000 323i AT
                            2016 Mazda CX3 Sport AWD
                            • immajackuup
                              • Dec 2010
                              • 1132
                              was thinking of buying that to save me the trouble in the long run.
