2002 maxima cuts off when put in neutral...
  • CreamE30
    • Mar 2008
    • 1177
    Hey all, my mom drives a 2002 maxima and its been having some issues lately, here's what has been happening:
    When I'm rolling up to a light, I'll push the clutch in, drop it in neutral and then let off the clutch. As the RPMs wind down, they will drop BELOW normal idle speed and every now and then it won't be able to recover and the engine will stall.
    What should I start looking at as the culprit of this issue?
    <---Goodnight, sweet prince
  • mikeedler
    • 6707
    vacuum leak somewhere. that would be my guess.
    • BMWerke
      • 893
      my e30 does this but it doesnt stall it recovers and its not a vacuum leak, i cant figure it out
      '90 325is DD, 5 spd swap-H&R springs-Euro Headlight Fully Built OBD1 M54b30. Ox Blood interior, 3.46 LSD with Z3M Diff Cover. Custom shifter, every bushing replaced.
      '86 325e- Donor car for swap/parts car
      '00 323i- BBS 197s Totalted
      '89 740 turbo Volvo- Donated
      • CreamE30
        • Mar 2008
        • 1177
        ^ Right, sometimes it recovers and sometimes it dies on me.
        • Dj Buttchug
          • Jun 2010
          • 7680
          idle control? OBDII is nice. put a scanner on it. may be able to pull some pre mature codes
          Turbo M42 Build Thread :Here
          Ig:ryno_pzk
          I like the tuna here.
          Originally posted by lambo
          • Farbin Kaiber
            Lil' Puppet
            • 29502
            I'll place my bet on the electronically controlled throttle body.
            • gearheadE30
              • Jun 2007
              • 3734
              I'm with farbin, or a vacuum leak.
              Project M42 Turbo
              • rickycricketts
                • 806
                Pull the dip stick when it's running. if nothing changes look for a vacuum leak. and yeah an obdII reader would be nice
