Engine Oil - German Castrol
  • mrsleeve
    • Mar 2005
    • 16387
    0wxxx is good for the more modern Higher tolerance engines and the oil pumps designed for it. The m20 is designed around the 20/50 weights, so 1) I just stuck with it, and if you want the diesel grades in 15/40 I would not be scared of either
    Originally posted by e30 335i
    hey 5toes i work at an oil manufacturing company and i defiantly wouldnt be running any diesel oils in a 20 year old motor. Diesel oils contain various additives for soot and other cleaning properties that will cause internal internal cleaning equaling oil leaks.
    Be careful what you read with marketing rubbish from oil companys. Also the word synthetic is a very bastardized word just thrown around in the industry.
    API- CJ-4 meets all the requirements for the all the Gas API standards, there is no reason to not run it in a gas engine. The anit soot and high tension formulation (for high boots high compression engines) has nothing but beneficial properties for the modern EGR engines
    Originally posted by Fusion
    William Pitt-
    • 5Toes
      • 9836
      Yeah I was thinking that too. Cleaner engines are better anyhow, and oil leeks just mean bad gaskets.
      Hmm I would be interested to see how a 5W40 or 5W50 synthetic would run in the m20
