my oil cap exploded!!!!!! HELP!!
  • e30mybaby
    • Jun 2010
    • 423
    but it shot out into the air! there was some major pressure in there!
    • Holland
      • Nov 2008
      • 7178
      Well I can't say I ever heard of an exploding oil cap before, although exploding rear glass takes the cake.
      Originally posted by DEV0 E30
      • coreyw
        • Jul 2010
        • 368
        Did you wash your engine with it running? Always start the car when you wash the engine, that way if water gets anywhere it shouldn't be itll burn up before it can puddle and do bad things.
        S52 Swap
        Shtuff For Sale
        • mamzak
          • 883
          Probably not a good idea to put cold water on hot metal repeatedly.
          All girls fuck but not all girls fuck around with combustion engines.
          • e30mybaby
            • Jun 2010
            • 423
            i was told to wash it when the engine is cold and then start it after to burn it off and thats what i always do!
            • trackjunkie21
              • Jan 2010
              • 3962
              Maybe the pcv was clogged and too much pressure built up? The cap could have been weak that's why it blew off.
              Originally posted by Wh33lhop
              VANOS: sometimes you just need to go full retard.
              • e30mybaby
                • Jun 2010
                • 423
                so i found out the gas cap and oil cap is the same! i love germans!! anyways after awhile it started without the oil cap on! then i put on the cap then started it it again and it exploded again and dies! it will only run on 3 cyl sometimes to now! it starts ok without the oil cap on but when its on it wont start most of the time and when it does it explodes!
                the last few weeks i have been burning a lot of oil and its been getting a little on the hot side!
                • Jean
                  • 18228
                  What condition is the m10 in, does it smoke? It must have some crazy amount of blow by or something....
                  • e30mybaby
                    • Jun 2010
                    • 423
                    its pretty good! i bought it with 140 and its got 170k now and the only problem i have had was the oil burning and getting a little hot! the e30 tick has gotten louder lately though! and in the last month it has started to burn a lot more!
                    • Dissembler
                      • Jul 2008
                      • 153
                      Sounds like your PCV system is completely plugged. When the crankcase can't vent, all the extra pressure travelled through the oil passages and into the head where it found the easiest way to relieve itself - the plastic oil cap. Also explains why the car stalls as soon as you put the oil cap on, and can run with it off.
                      Its not a matter of the M10 being so powerful that it can blow its oil cap, its about compression. All the excess pressure in the crankcase is stalling the pistons as they travel down. The more the engine runs, the more pressure that builds up in the crankcase until the engine stalls or blows the oil cap.
                      Pull the PCV and see if it runs okay.
                      • e30mybaby
                        • Jun 2010
                        • 423
                        ok ill check that!
                        this happens to though when im trying to start-
                        ps-this is not me lol i just found this! and its like the last 20 sec of the video!
                        • LJ851
                          • 7918
                          what is happening in that vid is a backfire in the intake. it might be possible for a backfire to work its way back to under the valve cover and blow your cap off. does your car have a dist cap ? its prob wet or you are crossfiring somehow cause you sprayed water all over your shit.
                          Lorin
                          The M30 is God's engine.
                          • e30mybaby
                            • Jun 2010
                            • 423
                            no its not wet i already checked all that!
                            • ttrousdell
                              • Nov 2009
                              • 1770
                              on the ships i worked on with huge diesels there are blast doors on the sides of the engines and on the doors are pressure relieve valves. there have been catastrophic engine explosions where the crankcase breather failed and lube oil vapors filled up the engine, ignited and blew apart the engine. i thinking you had a build up of flammable vapors
                              The Build:
                              • Raxe
                                • 5346
                                Man that's crazy! So it actually shot like a gun! Wow! I haven't heard of that happening before! Did it dent your hood at all! Probably not because it was plastic! If it was metal I'd be worried about that! You're lucky!
