Bmw e30 - Hunt for the 8sec is ON !!
  • karel
    • 234
    So time to make an thread for this winter adventures.
    A bit of info on the car then for those that havent had the time to see the green "hulk" before.
    The car then.
    BMW E30 2door
    plastic hood and trunk, and plastic windows in the back.
    Engine.
    M20b25 Drill ΓΈ stroked to 2.7L
    Ross Pistons
    Custom rods
    The head is an standard 2.5 with crmo retainers, stainless steel valves, and heavyduty rockers
    and PPF camshaft
    Its making 646whp and 832wnm at the moment
    With this power it made 9,6 and 235kmh at the 1/4 mile
    And this is with split rear end and a zf gearbox
    Now the target for 2011
    The powertrain will remain the same, the clutch setup will be changed if necessary.
    The goal is to hit the 8sec on the 1/4mile, to this then will need more than 646wheel horses.
    These components will be changed
    Fuel system, Turbo, cam, injectors and then new pistons
    the fuel system for this year will be completely from Weldon racing pump who is also a new sponsor for 2011
    fuel system
    Weldon 2345
    Regulator
    Weldon 2047
    Filters also from Weldon.
    And for the daily driver setup will need an Weldon Fuel pump controller
    (this will make the fuel much colder and also so the pump wont run att 100% all the time)
    injectors will be bosch 1600cc
    Turbo and cam is not clear yet, but its between a PT71 or BorgWarner 375 or 475
    More to come:)
    / Karel
    https://www.facebook.com/karelsilhamotorsport/
  • StereoInstaller1
    GAS
    • 22679
    Wow, what a beast.
    Any videos to share?
    Closing SOON!
    Thanks for 10 years of fun!
    • Kershaw
      • 11822
      good luck.
      im surprised you're using a zf gearbox and not a drag racing transmission. do you crash the gears?
      AWD > RWD
      • karel
        • 234
        Wow, what a beast.
        yeep here are some :)
        Originally posted by Kershaw
        good luck.
        nope havent crashed any yet :)
        doing an 8sek with an dragrace gearbox is the easy way, doing it with split rear end and zf gearbox is the hard way :)
        /karel
        • HarryPotter
          • Jan 2010
          • 3642
          BMWSOB is still my hero.
          John F. Kennedy
          • Pussy30
            • Feb 2011
            • 463
            Oh my god
            • CDBE30
              • Nov 2008
              • 76
              Jesus christ.
              • QUKBMER
                • 8178
                Here you go.repost i know.http://www.youtube.com/watch?v=gzSMSHQZKqY
                • karel
                  • 234
                  Originally posted by QUKBMER
                  yeep that a guy i know.
                  still dragracing gearbox, and ford 9" rear end
                  • Supadave
                    • 1006
                    That green monster is a beast. The other car ^^^ has so much power the frame is twisted.
                    https://www.r3vlimited.com/board/sho...d.php?t=420591 5.3 LSA build in progress :devil:
                    • QUKBMER
                      • 8178
                      Automatic or manual trans?
                      • karel
                        • 234
                        i think its manual, without the clutch but not sure.
                        • QUKBMER
                          • 8178
                          4 gears only built auto?
                          • HarryPotter
                            • Jan 2010
                            • 3642
                            John F. Kennedy
                            • karel
                              • 234
                              hmm could be? not sure about those gearboxes
