So I live in Michigan, Im flying down to Georgia to pick up my first clean E30 with around 200k on the odometer. what I know about it is it has a slight oil leak(no problem couple of gaskets), timing belt changed about 30k ago, 60% tread left on tires, guy says he drives it daily and it drives fine, states there is a slight vibration at around 35mph(most likely CSB), plugs and wires changed 3 oil changes ago, clutch is fine, breaks are fine, no over heating issues. My question is, being that I am going to make a 12hr journey home in this vehicle, what would you reccomend I do to it before I head out?
I figured, oil, plugs, gaskets(oil pan and valve cover), check all fluids..obvious stuff. Anything else?
