HELP: 2nd Gear whine
  • E923352E30325IS
    • Feb 2011
    • 44
    Hey guys, today I noticed a high pitched whine when im in 2nd gear. The car has been having difficulty getting in 3rd since day 1. Do you think it just needs some new transmission fluid? I can use all the advice there is
    Thanks!
  • z31maniac
    • 17566
    That's your only hope really. Put some Redline in it and see if it quiets down and shifts easier.
    www.gutenparts.com
    • E923352E30325IS
      • Feb 2011
      • 44
      yeah thats what was recommended to me by a friend who said it worked for him.
      Do i have to flush the transmission fluid or just top it off?
      • Mde36
        • 509
        Redline would help but just to get a little more info what kind of transmission do you have?
        Powered By Ford
        • z31maniac
          • 17566
          I'm assuming you have a manual, so just drain and refill.
          IIRC the G260 takes around 1.75L to fill.
          Pro-tip: Remove the "fill" plug before you remove the "drain" plug.
          www.gutenparts.com
          • quickervicar
            • 1197
            Quoted for truth
            • E923352E30325IS
              • Feb 2011
              • 44
              I have a 5-speed manual. Is there a DIY for this? How difficult is it to do in my garage?
              • Car Addict
                • Mar 2007
                • 1100
                Not hard at all here is your diy
                1) jack car up
                2) slide underneath with catch pan
                3) look up at trans
                4) locate large bolt on the passenger side of the transmission it is a 17mm Allen key
                5) remove said bolt
                6) look underneath trans
                7) locate the same size bolt as before
                8) remove bolt
                9) catch fluid
                10) replace bottom bolt
                11) fill trans with new fluid until it comes out the fill hole
                12) replace side bolt
                13) lower car
                14) drive e30
                • E923352E30325IS
                  • Feb 2011
                  • 44
                  1) jack car up
                  3) look up at trans
                  5) remove said bolt
                  8) remove bolt
                  9) catch fluid
                  13) lower car
                  14) drive e30
                  Got it! Thanks! Ill post any questions if I have trouble.
                  • E923352E30325IS
                    • Feb 2011
                    • 44
                    Where do i replace the trans fluid? Do i have to syphon it from the bottom or is there somewhere to pour it directly in from the engine bay?
                    • blefevre
                      • Dec 2008
                      • 4287
                      You need to use a pump to fill it in the upper plug, the one on the side of the trans.
                      - E30, DSM, Golf R, Mazda 3 Skyactiv
                      • Cabriolet
                        • 9620
                        you get a tube that is about 5 feet long with a funnel. and pour it down from the engine bay.
                        Much wow
                        I hate 4 doors
                        • Brandon12V
                          • 1318
                          worst case scenario, there is a guy in the who rebuilds getrag & zf transmissions for 7-800 bucks in the classifieds. he takes your core though so shipping may bite you but it's a good deal. be sure to check your rear output shaft and selector rod seals while you're under there otherwise you'll be replacing the trans fluid again, sooner than later. If you need help with this, pm me and I'll give you directions on how to replace them.
                          Originally posted by Ryan...
                          It now emits a beautiful blue-ish yellow/green smoke from the exhaust?? No idea what would cause that color, but I assume its good.
                          • E923352E30325IS
                            • Feb 2011
                            • 44
                            Should I also be replacing my differential fluid while im under there?
                            • mikeedler
                              • 6707
                              def. won't hurt to change that too.
