Need the help of R3V - Amputee Driving a Clutch
  • 5Toes
    • 9836
    #196
    Well more thought on this subject tonight and I have a good idea to present.
    Take a motorcycle clutch master cylinder. Doesnt even need to be a big one... and run a remote brake booster in the trunk. Vacuum assisted clutch yes?
    Any thoughts?
    EDIT: Seems that brake boosters do not multiply force therefore, this idea would not make the the motorcycle m/c stronger. Reading now how to boost hydraulic force..
    • gearheadE30
      • Jun 2007
      • 3734
      #197
      Brake MC's work exactly the same as a clutch MC on a motorcycle, but they are larger. If you figure out what diameter MC piston you need to drive the slave, you might be able to find something close. A lot of older motorcycles use 3 brake calipers, which requires the movement of a fair amount of fluid with quite a bit of mechanical advantage because there is no brake assist....
      Project M42 Turbo
      • 5Toes
        • 9836
        #198
        Thank you gearhead. Will look into it later today
        • turge
          • 2576
          #199
          Here's a thought. Buy a right hand drive car from the U.K.
          Anyways good luck with whatever route u take.
          Sent from my HTC ThunderBolt using Tapatalk
          • 5Toes
            • 9836
            #200
            And how does that help?
            • LJ851
              • 7919
              #201
              You Funny, 5Toes !
              Lorin
              The M30 is God's engine.
              • 5Toes
                • 9836
                #202
                I read this article, and the way it was worded was sort of weird
                Originally posted by wikipedia
                It uses a stored vacuum to multiply (assist - it is not a multiplier of force) braking force applied by the driver to the brake pedal
                • KenC
                  King of Kegstands
                  • 14396
                  #203
                  Lol pedals aren't reversed.
                  Originally posted by Gruelius
                  • turge
                    • 2576
                    #204
                    U said u wanted the accelerator on the left correct? Most UK cars have the steering wheel and what not on the right since their roads are reversed compared to ours.
                    • turge
                      • 2576
                      #205
                      I thought they were? The one I saw was.
                      • LJ851
                        • 7919
                        #206
                        You saw wrong.
                        Lorin
                        • tg318is
                          • Jun 2008
                          • 2052
                          #207
                          Wow...
                          Andrew, Good luck with it! Very interesting.
                          Tim.
                          • Holland
                            • Nov 2008
                            • 7212
                            #208
                            Pedals are not reversed on RHD cars.
                            Originally posted by DEV0 E30
                            • OniKyan
                              • Sep 2011
                              • 671
                              #209
                              Vtec has the best idea. If homeboy is actually capable of producing it, you should send him the $400.
                              M20B23 Euro 323i - The Legend Of Ron Burgundrot
                              • FunfGan
                                • Jan 2011
                                • 4958
                                #210
                                I'm sorry, but are you fucking joking?
                                Go here be happy!
                                Ratchet Garage e30 V8 build.
