Need the help of R3V - Amputee Driving a Clutch
  • 5Toes
    • 9836
    #226
    I will swap to a g260 one day... but no pedal changing will be done.. I can do this
    I will have an aluminium rod connected to the pedal via a ball joint type thing (so when I push down small angle changes can be accommodated)
    Then the stick will be kept in place by a u hook type thing around it, then all I have to do is push down, no looking at pedal to make sure it is on it or anything like that
    Should work... and the rod will have a pistol grip!
    EDIT: Damn I sound tooo excited. lol
    • 5Toes
      • 9836
      #227
      This ball joint would work great... then just put a nut on the end of the rod so that it can be removed
      http://www.ebay.com/itm/Replacement-...ht_2797wt_1110
      and titanium tubing..
      http://www.ebay.com/itm/TITANIUM-TUB...#ht_500wt_1361
      • Vtec?lol
        • Dec 2009
        • 3278
        #228
        Dude, Give me $400 and Ill fab you up a hydraulic operated and clutch/shifter.
        Parts list:
        Any motorcycle shorty brake lever with adjustable travel
        brake line
        brake hose
        a reducer
        and that's it.
        The master cylinder on sportbikes "twin quad piston brake lever" will easily move enough fluid to engage and dis-engage the clutch slave with minimal hand effort. Zero hand fatigue and one million clutch control.
        Lemme know
        • 5Toes
          • 9836
          #229
          ^ I have been told by multiple people that there is not enough pressure from a motorcycle m/c
          • Vtec?lol
            • Dec 2009
            • 3278
            #230
            lol they've told you wrong my friend.
            • camshaftgsxr
              • Aug 2011
              • 416
              #231
              Parts list:
              brake line
              brake hose
              a reducer
              and that's it.
              Lemme know
              this is what i was trying to get at, but much more thought out than my idea lol
              BroWorks.com Bro is a lifestyle
              • 5Toes
                • 9836
                #232
                reducer is to give more hydraulic pressure?
                • homegrone30
                  • Jun 2007
                  • 1449
                  #233
                  Ive been talking to my Dad about figuring something out. Hes a left leg below the knee amputee. We want to figure out a way that he could drive with his nub and I have a loose nit idea but its just that an idea.
                  • Wild Ride
                    • Apr 2008
                    • 739
                    #234
                    There is a company based in SD that builds mobility kits for the impaired. On the e92 m3 I saw the throttle was operated by a halo that was the same diameter as the steering wheel and rotated with the wheel. If you pulled the halo towards the wheel and away from the dash it would add throttle. Sorry I can't find a link but that may give you an idea.
                    • BigTe30
                      • 207
                      #235
                      Parts list:
                      brake line
                      brake hose
                      a reducer
                      and that's it.
                      Lemme know
                      If you build it they will come
                      • 5Toes
                        • 9836
                        #236
                        I guess I need to get my hands on a beefy motorcycle master cylinder and an e30 master and go down to the local hydraulic shop. They can measure the pressure output of each one
                        • Pantless Spency
                          It's McRib time!!!
                          • Feb 2011
                          • 7283
                          #237
                          modifications can not be mad to master cylinders, there no way at all dude.
                          • LJ851
                            • 7919
                            #238
                            Lemme know
                            With all due respect, your head is up your ass.
                            No, you are wrong.
                            You quite possibly could find a motorcycle M/C thats moves enough fluid but it will be anything but "minimal hand effort". A hydraulic master and slave system is just simple leverage and there is no free leverage!
                            Think about pushing your clutch pedal with your hand, it has to move several inches and is hard to push. Wanna make it easier to push? Now you have to push the lever (pedal) even farther. As a side effect you just lost all your "feel" of the engagement point because it is so broad now.
                            Lorin
                            The M30 is God's engine.
                            • Swanny
                              • Mar 2012
                              • 2834
                              #239
                              feet are for bitches
                              Swanny!
                              SUCKERS.
                              • DaveSmed
                                • Apr 2007
                                • 1407
                                #240
                                Measure the pressure of each one?
                                I suppose hydraulics are a bit of a mystery or something, shit.
                                It's all in the ratios. If you engineer the system so the ratios work out to be similar, your in good shape. Most of the force multiplication in the part of the system you are interested in modifying comes from the leverage of the clutch pedal.
                                The stock E30 hydraulics barely do anything more than a clutch cable, which is transfer force from one place to another.
                                How do I come to this conclusion? The diameter of the input cylinder, the clutch master, is 19.05mm according to RealOEM. The diameter of the output cylinder is 20.64mm. Already, you can see that they are close to the same size.
                                Calculating the area of each cylinder gives us 284.88 sq mm for the master, and 334.42 sq mm for the slave. Dividing those two numbers tells us that we will get 1.1738 times the force out of the slave that we put into the master.
                                So, if you push with 100lbs of force on the master cyl, you will get 117.38lbs of force at the slave. Not a real impressive multiplication of force in this application. There's also a catch. Say we push on the master and move it 2 cm. The ratio works backwards as far as movement goes, so the slave is only going to move 1.7cm.
                                The real obstacle then is not only replacing the leverage of the clutch pedal, but keeping in mind that the average person's leg is 4x stronger than their arm, let alone their hand. You will need to add some mechanical advantage somewhere or else it will be a very fatiguing car for you to drive.
                                Or maybe a magical "hydraulic reducer" is all you need. ;)
                                -Dave
                                2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
                                Need some help figuring out the ETM?
