Tucking/painting DB's
  • Pantless Spency
    It's McRib time!!!
    • Feb 2011
    • 7283
    soo0o0o0oo0o.
    i want to tuck my DB's but honestly i'm too much of a waffleswaffleswaffleswaffleswaffles to drive my car into a tire against a wall :)
    is there any other way to do this?
    i was thinking what if i took the bumpers off, as well as the shocks, then i drill a whole in the shock so it can lose fluid, and compress it in a vice?
    would this workk...
    also,
    i want to paint my DB's
    i was thinking, i'll paint the outer plastic trim the zinno color my car is, which could be expensive? and then for the DB itself i'm not sure if it would look better painted zinno also with the black trim, or painted black... i sorta like the way ubernasty did his with the black bumper and matching plastic outer trim.
    (example of his car)
  • Holland
    • Nov 2008
    • 7212
    That would be the proper way to do it, just wear a mask.
    Originally posted by DEV0 E30
    • mettaxa
      • 25
      i didn't have to drive my car into a wall when i tucked my db's lol
      • Teaguer
        • Sep 2004
        • 6167
        The shock oil is under pressure so as soon as you drill them they will spray out in a violent matter or fog out in a fine mist.
        So maybe you should read up a little more so you know whats going on.
        Not that hard though. take them off, drill into them but keep a rag or some sort of cover between the drilled area and your face.
        Once drilled you can hit them with a hammer or whatever. A vice probably will not work as it may not open wide enough.
        I've always drilled into them whil on the car then either pushed, kicked or hammer (while protecting the bumper) them in.
        But I'm in TX so there is no rust or seizing to worry about.
        As far as painting them or the surrounds goes, the later metal bumpered verts all came with smooth body colored surrounds from the factory.
        Painting the surrounds and bumper itself while keeping the impact strip always looks the cleanest.
        • Pantless Spency
          It's McRib time!!!
          • Feb 2011
          • 7283
          thanks for the info guis, i'm not too sure about spraying them myself tho :P
          i would fuck that up so bad...
          how much you think a decent shop would charge to spray both surrounds and metal bumpers with the zinno color code?
          • beenjamin
            • Jul 2010
            • 323
            at least $700
            Originally posted by Jafxod
            Fuck, I need to find me a girl friend for this winter to nestle my penis inside and keep it warm.
            • Pantless Spency
              It's McRib time!!!
              • Feb 2011
              • 7283
              fawk my ass!
              i'm just gonna get the right paint and bring it to maaco where danny works hahaha.
              • Teaguer
                • Sep 2004
                • 6167
                Originally posted by beenjamin
                at least $700
                Yiikes! You iz on crack homeboy!
                Decent competent shop could charge $200 for single stage with labor included.
                • beenjamin
                  • Jul 2010
                  • 323
                  then central california are a bunch of overpricers. I do my shit myself so maybe i just don't get out enough to ask the right people.
                  • Pantless Spency
                    It's McRib time!!!
                    • Feb 2011
                    • 7283
                    could do any prep work,
                    would i prep the plastics by sanding them so the paint will stay?
                    • Simon S
                      • Oct 2004
                      • 3758
                      Agreed.
                      Just do it yourself. Cheapest and most rewarding. Not sure but I think there are areas from surround which should be trimmed to prevent ‘wavyness’ – or maybe they all do that with enough sun damage.
                      Clean/scuff/prep well.
                      Take you time and bomb it with appropriate color from Automotive TouchUp
                      Plastic adhesion promoter for surrounds. Primer for metal. Color. Clear. Great tips. No other equipment to buy.
                      Do some reading. You’ll want to colorsand/buff out clearcoat when you’re done anyway – so it doesn’t have to be perfect.
                      Use SEM black for trim.
                      I think the biggest bitches would be getting old hardware off – and scuffing down chrome on bumper.
                      Tape, sandpaper, and paint for ~$80?
                      Shit - I guess you wouldn't even need tape so long as all parts were off the car..
                      -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
                      • beenjamin
                        • Jul 2010
                        • 323
                        I'de hate to give you the wrong information, but letting a shop do the whole project is smarter IMO. They'll most likely re-sand your bumpers anyways. Plus, they might charge you the same price for if you had done them in the first place. Save money, the economy blows.
                        • Simon S
                          • Oct 2004
                          • 3758
                          That is a good point.
                          • Pantless Spency
                            It's McRib time!!!
                            • Feb 2011
                            • 7283
                            i think i'm pretty competent for this...
                            simon you're saying to do it with some cans? but the right colored cans right?
                            but would it look as glossy as the ones above on ubernasty's if i did it with can paint and can clearcoat?
                            • bernzpeed
                              • 3917
                              or you're just gullible.
                              89 E30 S52
                              Transaction Feedback.
