Help!!!! No compression in #6 cylinder
    I just did a rebuild on my m20 block and my #6 cylinder has 0 compression. Cylinders 1-5 have 160psi compression.
    Think it may be a burnt valve because before I took the engine apart I couldnt rev past 2k under load. Now I can.
    Define "rebuild" did you do the head as well? I agree that it is probably valve related.
    '89 Alpine S52 with goodies
      I did the head couple weeks back before the block rebuild... The reason I rebuilt the block was because after putting the new head on I blew the rings
        Redundant double thread is redundant.
          How many miles? Because if it's 200k? You don't need to rebuild.
            Don't know odo doesn't work.... But already did the rebuild
              If the rings are ok i would start looking at who did the valve job. Maybe the valves are not seated well?
                The valves were fine b4 the rings blew out
                  Do a leak down test. That should pin point your problem.
                  :borg:
                    pull the head and have it pressure tested, im also thinking valves.
                    did you set the ring gap placement correctly?
                    IX being restored here
                    Ix turbo build here
                      This.
                      A compression test is essentially worthless in this situation.
                      I never test compression, only leakdown.
                      Turbo Cabrio project: http://eurowerks.org/showthread.php?t=19677
                        Trying to get my hands on a leakdown test for tomorrow. Thanks for all the inputs. I've been thinking valves too just wanted to have other inputs
